NOVA 9F Series Air-Cooled Flex-Neck TIG Torch 25 Ft. 35 DINSE-Type Connector (No Gas Thru), view 1
NOVA 9F Series Air-Cooled Flex-Neck TIG Torch 25 Ft. 35 DINSE-Type Connector (No Gas Thru), view 2
SKU# NVA-9F-250-UF-35QD
9 Series (125A Max)
$149.00
9 Series (125A Max)
  • Unit Weight: 4 lb
  • Shipping Weight: 6 lb
The NOVA 9F Series Air-Cooled TIG torch (3.0 Version) features a flexible neck design with improved durability and flexibility of the Ultra-Flex torch cables over previous Nova 1.0 and 2.0 versions. The flex-neck torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. The flexible neck is rated to flex up to 40 degrees (for best life limit to 35 degrees) up or down. It is rated for 125A DC and 80 A AC use at 60% duty cycle. The traditional single line cable-in-gas-line design maximizes portability and reduces total weight thanks to the silicone based torch cables. While the torch can be used at higher Amperages, the user should be conscious of the limits of the torch. The 35 DINSE-Type power connector measures approximately 1/2" in diameter at the connector pin. and fits Everlast all Everlast PowerTIG, PowerPro, and Typhoon, Lightning and Thunder units that are rated for 200A or more with automatic gas control. It also fits later model PowerTIG 185 units, PowerPro 164Si and others. NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector. This is not a gas-valve torch. 2T/4T torch switch included. (The switch is meant to control the remote program settings preset on the panel and does not directly control Amperage on the torch).
80 Amps
125 Amps
Torch Neck Type
Flex
Torch Service Type
Torch Handle Type
Torch Remote Switch Included
Torch Cable Type
Ultra-Flex (Silicone)
Number of Main Cables
Single Line Air-Cooled
Cable Length
25 Ft.
Cable Power Adapter Size/Type
DINSE 35 Type (Solid)
Gas Connector Type
Protective Cable Cover Type:
Denim
