NOVA HD PowerCart 375LF Welding Cart with Single Cylinder Capacity, view 1
NOVA HD PowerCart 375LF Welding Cart with Single Cylinder Capacity, view 2
NOVA HD PowerCart 375LF Welding Cart with Single Cylinder Capacity, view 3
NOVA HD PowerCart 375LF Welding Cart with Single Cylinder Capacity, view 4
SKU# PC-375LF
Welding Carts (See Also Welding Tables)
$229.00
$199.00
Save - $30.00
SKU# PC-375LF
  • Unit Weight: 53 lb
  • Shipping Weight: 56 lb
  • Unit Dimensions: 18.9 in × 43.3 in × 37.79 in
The NOVA PowerCart 375LF is a long-framed heavy duty cart designed to hold up to 375 lbs. worth of welder, water cooler, welding accessories and gas cylinder. The cart features over-sized, easy rolling 10" rear wheels, locking front casters and tubular frame construction. The top shelf easily accommodates welders up to 25" long and 10 inches wide. The design of the cart fits most Everlast welders, water coolers 330A and under (except Lightning 275 which uses a different cart). It can also be used with any plasma cutter 100A or under. The cylinder rack holds most cylinders up to 9" in diameter. The cart is designed with an additional storage tray and consumable box to capture all your welding "extras" like foot pedals, gloves, sleeves, filters etc. The bottom shelf can be used to store larger items like grinders, picking hammers, and other welding tools. The cart also has multiple hooks on either side to wind up your cables when not in use or to hang your welding helmet The cross bar support can be fitted to either side for for MIG welders that may have doors on either side of the machine.
This cart not only is a good fit for Everlast welders, it is a good fit for almost any brand welder.
Maximum Gross Weight Capacity
375 lbs.
Maximum Cylinder Size Supported
9"
Casters/Wheels
Yes, 2 Swivel Locking and 2 Straight
