NOVA Rota-Flex 18 Water-Cooled TIG Torch 25 Ft 35 DINSE-Type Connector (No-Gas Thru), view 1
SKU# NVA-RF18-250-UF-35QD
18 Series
$209.00
18 Series
  • Unit Weight: 5 lb
  • Shipping Weight: 7 lb
The NOVA Rota-Flex18 Series Water-Cooled TIG torch (3.0 Version) features a swivel-head design that allows the torch to rotate a full 360 degrees and lock in place at whatever angle is desired. The offset neck also helps to improve welding angle and improves access to tight locations. The Ultra-Flex torch cables of the 3.0 version offers improved durability over Nova 1.0 and 2.0 versions by using food grade silicon hoses. The torch design is of a universal WP- type TIG torch design which means compatible consumables are available at almost any local welding supply store that sells TIG accessories. On the 3.0 Versions, the orifice sizes in the head have been increased to provide better air flow and water circulation. The sturdy fixed neck design is meant for rugged use and resists torch breakage. It is rated for 350 Amps DC and 250 Amps AC use at 100% duty cycle. The traditional single line cable-in-gas-line design maximizes portability and reduces total weight thanks to the silicone based torch cables. While the torch can be used at higher Amperages, the user should be conscious of the limits of the torch. The 35 DINSE-Type power connector measures approximately 1/2" in diameter at the connector pin. and fits Everlast all Everlast PowerTIG, PowerPro, and Typhoon, Lightning and Thunder units that are rated for 200A or more with automatic gas control. It also fits later model PowerTIG 185 units, PowerPro 164Si and others. NOTE: Measure inside female diameter of the machine-side power connector to confirm fit. DINSE 25 connectors are smaller and measure approximately 3/8" inside the female connector. This is not a gas-valve torch.
250 Amps
100%
350 Amps
100%
Torch Neck Type
Roto-Flex
Torch Service Type
Torch Handle Type
Torch Cable Type
Ultra-Flex (Silicone)
Number of Main Cables
Three Line Water Cooled
Cable Length
25 Ft.
Cable Power Adapter Size/Type
DINSE 35 Type (Solid)
Gas Connector Type
Water Connector Type
