NOVA Tru-Fab 48"X30"X36" Mobile Rolling Welding Cart
SKU# NVA-TBL-483036-F203805013
- Unit Weight: 312 lb
- Unit Dimensions: 48 in × 30 in × 36 in
The NOVA Tru-Fab 48"X30"X36" Welding Cart is a portable table with 2 swivel casters and 2 fixed 5" heavy-duty casters that allows the table to be used as a welding cart and can be wheeled anywhere in the shop or the job site. Locking casters and leveling feet help ensure the table is steady and level for any application. The table can also double as a basic cart for your welder with additional shelving underneath which can hold your welding equipment with an upper 22.5X21X18" Shelf for small welders and another lower 22.5"X19.5"X27" lower shelf for taller items. The table also has a handle to help manuever the table around. The side features standard peg-style wall which can support related tools and equipment with standard type peg hooks and peg hook accessories.
The heavy-duty blanchard ground table top is 12mm thick (.47") is accurate and flat for general purpose layout and welding and uses standard 5/8" holes on 2"x2" standard spacing. The surface is nitrided (HV500) to a depth of .2mm and features a black-oxide finish which minimizes reflectivity and helps prevent spatter from sticking. The steel table top is made from Q355 steel (equivalent to ASTM A572 Gr50). The tubing frame adds additional rigidity and strength to the top. The table is rated for a weight up to 1500 lbs.
| Maximum Gross Weight Capacity | 1500 lbs.
| Table Top Thickness | .47" (12mm)
| Table Height | 36
| Adjustable Height | Yes
| Casters/Wheels | Yes, 2 Swivel and 2 Straight
| Tool Kit Included | Optional
