Parker DSP 240A Spool Gun (7 Pin) 25 Ft. Euro Quick Connect, view 1
Parker DSP 240A Spool Gun (7 Pin) 25 Ft. Euro Quick Connect, view 2
SKU# EV-DSP240A-24-P1-60ER
Pistol Grip
$399.00
Pistol Grip
  • Unit Weight: 10 lb
  • Shipping Weight: 12 lb
  • Unit Dimensions: 24 in × 24 in
The Parker DSP240A is a heavy duty, 250A (maximum) air-cooled spool gun that will run with the best of them. The unit features adjustable Wire Feed Speed/ Amp control on the gun and a 1000 hour life motor. The unit natively fits the Lightning 212 MTS. It is also recommended for the Cyclone 212i, Hurricane 220 MTS-C, Lightning 225 MTS and Thunder 215 Models with the small 7 pin connector. Not recommended for any other models. This model ships with a .040" aluminum drive roll. However, it can be equipped with other optional sizes of Aluminum or Steel drive roll sizes. Be sure to purchase additional drive rolls to fit the size wire you will be using. Drive roll ranges available: .8mm (.030") to 1.2mm (.045/.047/ 3/64") for Aluminum amd .8 (.030") to 1.0mm (.040) for steel/stainless.
CO2 Amperage Rating
220 Amps
CO2 Duty Cycle @ Amperage Rating
35%
Ar/CO2 Amperage Rating
Ar/CO2 Duty Cycle @ Amperage Rating
35%
Gun Neck Type
Straight
Stock Drive Roll Size(s)
.040"/1.0mm
Amp Control Type
Amp/Wire Feed Control on Gun
Cable Length
25/8Ft./Meters
Cable Connector Type
Euro-Quick
Protective Cable Cover Type
None
