Parker SGP 360A Air-Cooled Push-Pull Gun (7 Pin) 25 Ft. Euro Quick Connect
SKU# EV-SGP360A-V2
- Unit Weight: 12 lb
- Shipping Weight: 14 lb
- Unit Dimensions: 24 in × 24 in × 16 in
The 300A Parker SGP 360A air-cooled push-pull gun natively fits new Cyclone 262i, 312i, 263Pi, 313Pi, 253DPi and 353DPI. It also fits new-style Lightning 275/ 275P models as well as Thunder215 and 255 models that are push-pull capable. It comes fitted with a .045" drive roll for feeding Aluminum. Additional Drive rolls available as an option It can also be retrofitted to work with older Power i-MIG models that feature push-pull capability such as the Power i-MIG 253DPi and Power i-MIG 353DPi, This cannot be used on older Lightning or PowerMTS models. ThisPistol Grip gun comes the larger 7 pin connector and will require a 2 pin adapter to work with older Power i-MIG models mentioned above. This design allows Wire Feed/Amp control at the gun on all new models. Wire feed speed control on the gun is only supported on newer models. The speed control on older models will not work and wire speed control must be controlled on the panel. NOTE: This gun uses standard 36 Series type consumables.
| CO2 Amperage Rating | 300 Amps
| CO2 Duty Cycle @ Amperage Rating | 60%
| Ar/CO2 Amperage Rating | 270 Amps
| Ar/CO2 Duty Cycle @ Amperage Rating | 60%
| Gun Neck Type | Straight
| Stock Drive Roll Size(s) | .045/.047"(3/64")/1.2mm
| Amp Control Type | Amp/Wire Feed Control on Gun
| Cable Connector Type | Euro-Quick
