PowerCool W500 (240V), view 1
PowerCool W500 (240V), view 2
PowerCool W500 (240V), view 3
SKU# PCW500-240
Water Coolers
$649.00
Water Coolers
SKU# PCW500-240
  • Unit Weight: 50 lb
  • Shipping Weight: 55 lb
  • Unit Dimensions: 11 in × 26 in × 10 in
The 240V PowerCool W500 is designed specifically to stack under the large frame Typhoon 500 and fits all Everlast torches without need for adapters. It can be used as a stand alone cooler however, and can be used beside almost all Everlast TIG and multiprocess units. These coolers are a solid, reliable cooler choice with copper core heat exchanger (radiator), stainless steel pumps with a brass impeller, and B-type 9mm color coded cooler fittings that can fit Everlast brand torches and welders natively. The cooler's flow rate is at a standard 1.1 liters per minute. With a two gallon capacity reservoir combined with the large heat exchanger, the welder can be used to cool torches up to 500A. A heavy duty pump and sealed industrial motor (made in Italy) are at the heart of the unit and designed for long life service. The direct drive means there are no belts or pulleys to service or maintain.
NOTICE: Everlast is aware that customers may be using various types of coolant in their PowerCool water coolers and with our NOVA or other brand TIG torches. These range from distilled water to Isopropyl alcohol to automotive type anti-freeze to R.V. anti-freeze to “private concoctions”. Since the PowerCool product line was released over 12 years ago we’ve gathered valuable data and gained experience concerning the use of coolants and their impact on both the lifespan of the cooler and the TIG torches themselves. With that said, there are several areas of concern that we look for in a coolant. We have found that most popular alternatives fail to provide satisfactory performance. We have taken our findings and concerns and listed them below as basic elementary requirements needed for best performance and product life.
Answer: While we are hesitant to endorse one product like this over the other or demand that any one brand of coolant be used, commercial brands like Praxair, Airgas, Miller, ITW, and Lincoln all provide satisfactory coolants that address the concerns above. There may be others. But extremely low priced coolants, or off brands may not provide the level of protection required. Again, read the label before purchasing and using. Use due diligence in selecting your coolant.
Input Voltage
240V
Input Amps
1.1A
Recommended Maximum Output Amperage
500A
Power Plug Type
IEC 60320-1 C-13
Cooler Flow Alarm
Use With These Units
Typhoon 500 (large frame older model. See picture above.)
Type of Coolant Permissible
TIG low conductivity or MIG coolant depending upon application.
Pump Type
Vane-Type
Pump Construction Type
Stainless housing with Bronze Impeller
Pump Output
1.1 LPM after bypass
Motor Type
Sealed Industrial
Heat Exchanger (Radiator) Material Type
Copper Core with Aluminum Fins
Reservoir Size
2.2 gallons approx.
Torch Connection Type
Color Coded Quick Connect Coupler
