PowerARC 210STL
PowerARC 210STL, view 2
PowerARC 210STL
SKU# PA-210STL
PowerARC 210STL
$519.00
$439.00
Save - $80.00
PowerARC 210STL
SKU# PA-210STL
  • Unit Weight: 25 lb
  • Shipping Weight: 30 lb
  • Unit Dimensions: 7 in × 16 in × 13 in
PowerARC 210STL
The PowerARC 210STL gives professional welders a straightforward way to get to work without giving up control. This compact inverter welder delivers a stable DC arc with a wide range of stick electrodes, including E6010 and other cellulosic rods. Adjustable Hot Start and Arc Force let you tailor arc performance to the job, while Anti-Stick and voltage reduction features add practical protection.
When the job calls for TIG, the PowerARC 210STL also offers DC Lift Start for applications such as root passes and stainless steel sanitary welds. Choose live lift or remote lift operation; remote operation supports a torch switch or optional foot pedal. A built-in gas solenoid automatically controls shielding gas flow.
Considering the light weight and compact design of this unit, this unit can be used almost anywhere. For portable repair situations where 240V may not always be available, the welder will also operate on 120V (at reduced output) so that it can be used almost anywhere welding is needed.
  1. Dual Voltage 120/240V Input for maximum portability
  2. VRD (Voltage Reduction Device) Lowers OCV in stick mode for safety
  3. Arc force improves performance as arc length varies.
  4. Hot start improves arc starting capability
  5. E6010/Cellulose settings
  6. Smooth, stable arc
  7. DC TIG function with lift start (Both Live and Remote lift capability)
  8. Optional Foot pedal control
  9. Anti Stick function to keep from flaming rods if rod becomes stuck
9,500 Watts Surge Rating
TIG Operation:
The unit features DC TIG operation and supports the ability to use an optional foot pedal.
TIG Torch and pedal are optional.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 38.8 A
240V 1 Phase 50/60Hz: 38.6 A
120V 1 Phase 50/60Hz: 22 A
240V 1 Phase 50/60Hz: 23 A
Stick Duty Cycle 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 120A/24.8V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 90A/23.6V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 70A/22.8V Rated Output
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 200A/28V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
Stick Output Range 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 120 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24.8 Volts
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 200 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 28 Volts
78 (VRD 10)V
Hot Start
Adjustable
Hot Start Time
Adjustable
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
5/32"-3/16"
TIG Function
Built In Gas Valve Standard Torch
Other Stick Functions
TIG Torch is optional
Recommended Range of Welding Rod Diameters*:
1/16"- 5/32"
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
.015" to 1/4"
.015" to 1/4"
  • Rail Car Industry
  • Pipe and Structural
