PowerMTS 141Si
SKU# PMTS-141SI
- Unit Dimensions: 8.5 in × 17 in × 12 in
Lightweight, compact, and easy to carry, the PowerMTS 141Si is an ideal welding companion for do-it-yourselfers and portable repair operations. Operating on 120V power, it combines 140A MIG, 140A DC TIG, and 80A DC Stick capability in one convenient package. Move from garage projects to on-site repairs with the versatility to handle several welding processes without hauling multiple machines.
MIG mode supports .023" and .030" wire with 4" or 8" spools, plus flux-cored welding with the appropriate drive rolls and aluminum welding with an optional spool gun. DC TIG offers HF or Lift Start, automatic gas control, a dedicated gas inlet, and optional foot pedal control for precise work on steel, stainless steel, and titanium. Stick mode handles popular 3/32" electrodes, including E7014, E7018, and most E6011 rods; it is not designed for E6010.
Simple controls and a bright LED display make setup easy to learn. With MIG and TIG output suited to 1/8" steel in a single pass and material up to 1/4" with multiple passes, the PowerMTS 141Si brings practical capability to home fabrication, maintenance, and mobile repairs—all backed by a 5-year parts and labor warranty.
- Operates on 120V power
- DC HF Start TIG for touchless starting
- MIG, TIG and Stick welding
- Compact, inverter design
- holds 4" and 8" spools of wire (2 and 10 to 12 lb spools)
- Can be used with Foot pedal for TIG
- Surge Watts: 4500W
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 37 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 19 A
| LCD Screen | No
| Memory | No
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 140A/21V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 90A/18.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 70A/17.5V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 140 Amps
120V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 21 Volts
| Pre-Flow Time | Auto Controlled Seconds
| Post-Flow Time | Auto Controlled Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
| Stock Drive Roll Wire Sizes Installed | .023”
.030”
V-Groove
| Number of Wire Drive Rolls (Top and Bottom) | 2
| Water Cooler Capable | No
| Spool Gun Capable | Yes
| Push Pull Gun Capable | No
| Wire Feed Speed | 425
| Torch/Gun | 15 Series 10 Ft.
| Important MIG Specification Notes | Spool Gun may be used, but best results are obtained with a polymer liner installed on the gun and U-Groove driver rolls installed to feed Aluminum wire. For best results use .047" wire. Smaller wire may not weld satisfactorily with either the standard MIG gun or the Spool gun due to low wire speeds of this unit.
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 140A/15.6V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 90A/13.6V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 70A/12.8V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 140 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 15.6 Volts
Lift Start With Remote
HF Start with Point Gap Start
| Pre-Flow Time | Auto Control/OFF Seconds
| Post-Flow Time | Auto Control/OFF Seconds
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 80A/23.2V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 60A/22.2V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 40A/21.6V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 80 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 23.2 Volts
| Hot Start | Fixed
| Hot Start Time | Fixed
| Arc Force | Fixed
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 3/32"
24 gauge to 3/16"
20 gauge to 3/16"
1/8"- 3/16"
.015" to 3/16"
.015" to 3/16"
NOT FOR USE WITH ALUMINUM.
1/16"- 3/32"
- 15 Series MIG Gun 3 m 10 ft.
- NOVA 17 Series Air-Cooled Rigid-Neck TIG Torch 12.5 Ft. 25 DINSE-Type Connector (No Gas Thru)
- Drive Roll V-Groove Single (Steel/Stainless) – .023"-.030" (0.6-0.8mm)
- Starter TIG Consumable KIT (Tungsten not included)
- Power Cable with NEMA 5-15 PowerPlug
