SKU# PP160H
PowerPlasma 160H
Hand or CNC Cutting
$3,999.00
PowerPlasma 160H
Hand or CNC Cutting
SKU# PP160H
  • Unit Weight: 125 lb
  • Shipping Weight: 150 lb
  • Unit Dimensions: 11 in × 26 in × 24 in
PowerPlasma 160H
The PowerPlasma 160H is for Industrial use only with hand cutting or CNC plasma table use. This unit has enough power to slice cleanly through materials 2+ inches thick. While this table has CNC capability it must be used with industrial CNC tables which are fully shielded from HF energy created by large plasma cutting units during start and operation. The High Frequency used to start the arc is common with plasma cutting units over 125A. Keep in mind this is not for small shops, or home garage use. The requirements of this unit are significant in both power supply and in air supply.
  1. For use with Industrial Hand or CNC Cutting operations only
  2. Water-Cooled Cutting or Air Cooled cutting operation
  3. Industrial Duty Cycle @ 60% at 160A
Generator Use:
Not Recommended
CNC Use:
Must be used with industrial shielded plasma tables.
480V 1 Phase 50/60Hz
480V 1 Phase 50/60Hz: 35 A
480V 1 Phase 50/60Hz: 28 A
Plasma Duty Cycle 480V 1 Phase 50/60Hz
480V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/144V Rated Output
480V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/132V Rated Output
300V
Arc Start Type
High Frequency (HF)
CNC Capable/Ready
Yes, with optional Torch
Drag Cutting
Post Flow Timer
Adjustable
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
15 CFH
Maximum Supply Pressure
120 PSI
Compressor Built In
60 Gallon
65-80psi depending upon torch type
Remote
Tip Saver Function
Location of CNC Port
Rear
CNC Port Type
WEiPU SP21 CNC Connector 12 Pin
Torch Connector Type
Threaded Type
Important Plasma Specification Notes
Use only with shielded plasma tables. When hand cutting, use appropriate PPE. Use a minimum of Shade 12 when cutting by hand.
  • Rail Car Industry
  • Pipe and Structural
