PowerTIG 185 DV, view 1
Group View of PowerTIG 185DV and Accessories
Side Panel View of the PowerTIG 185 DV
Rear Panel View of the PowerTIG 185DV
SKU# PT-185-DV
PowerTIG 185 DV
Analog AC/DC
$925.00
$799.00
Save - $126.00
PowerTIG 185 DV
Analog AC/DC
SKU# PT-185-DV
  • Unit Weight: 40 lb
  • Shipping Weight: 50 lb
  • Unit Dimensions: 7.5 in × 21.8 in × 12.8 in
PowerTIG 185 DV
The versatile PowerTIG 185DV is well suited for applications ranging from home shops to portable field work. With AC/DC TIG capability, it can weld a wide range of metals, up to 3/16" thick. This includes aluminum, stainless steel, mild steel, and titanium. Its dual-voltage design allows operation on either 120V or 240V input power while maintaining excellent arc quality. When operating on 120V input power, maximum output amperage is reduced.
With up to 185 amps of output, the PowerTIG 185DV provides the essential controls needed for a wide variety of TIG welding applications. Adjustable AC balance and AC frequency give the operator greater control when welding aluminum, while the preset two-speed pulse function operates in both AC and DC TIG modes. The selectable 1 Hz and 50 Hz pulse settings provide useful options for a broad range of welding situations without adding unnecessary setup complexity.
The PowerTIG 185DV comes with a basic welding package, making it nearly ready to weld right out of the box. Included are a TIG torch, foot pedal, regulator, work clamp, basic consumables starter kit, 240V NEMA 6-50 plug, and a 120V NEMA 5-15 plug.
  1. Dual Voltage 120V/240V
  2. Duty Cycle 185A @35%
  3. Simplified Pulse TIG in AC or DC 1 or 50Hz selection
  4. AC Frequency and Balance Control
  5. Stick welding capability
  2. 7500 Surge Watts
  2. E6011 use is permissible
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 29 A
120V 1 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 17 A
21S
On-Arc
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 185A/17.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 145A/15.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 110A/14.4V Rated Output
120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 15.0 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15.0 Volts
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 185 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 17.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 185 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.8 to 17.4 Volts
74V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
Fixed
Start Amp Range DC
Fixed
End Amp Range AC
Fixed
End Amp Range DC
Fixed
Fixed
0-25 Seconds
Fixed
0-10 Seconds
TIG Pulse
AC
AC Pulse Type
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
1 or 50 Hz
AC Pulse Frequency
1 or 50 Hz
Fixed
AC Frequency
20-250 Hz
AC Balance
10-90% of Positive Electrode
AC Wave Forms
Square
Other Functions
Dual Voltage
.007" to 3/16"
.007" to 3/16"
.025"- 3/16"
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical, recommended single pass limit based on the industry standard of performing thicker welds with multiple passes.
1/16"- 1/8"
