PowerTIG 185DV
SKU# PT-185DV
- Unit Weight: 40 lb
- Shipping Weight: 50 lb
- Unit Dimensions: 7.5 in × 21.8 in × 12.8 in
The versatile PowerTIG 185DV is well suited for applications ranging from home shops to portable field work. With AC/DC TIG capability, it can weld a wide range of metals, up to 3/16" thick. This includes aluminum, stainless steel, mild steel, and titanium. Its dual-voltage design allows operation on either 120V or 240V input power while maintaining excellent arc quality. When operating on 120V input power, maximum output amperage is reduced.
With up to 185 amps of output, the PowerTIG 185DV provides the essential controls needed for a wide variety of TIG welding applications. Adjustable AC balance and AC frequency give the operator greater control when welding aluminum, while the preset two-speed pulse function operates in both AC and DC TIG modes. The selectable 1 Hz and 50 Hz pulse settings provide useful options for a broad range of welding situations without adding unnecessary setup complexity.
The PowerTIG 185DV comes with a basic welding package, making it nearly ready to weld right out of the box. Included are a TIG torch, foot pedal, regulator, work clamp, basic consumables starter kit, 240V NEMA 6-50 plug, and a 120V NEMA 5-15 plug.
- Dual Voltage 120V/240V
- Duty Cycle 185A @35%
- Simplified Pulse TIG in AC or DC 1 or 50Hz selection
- AC Frequency and Balance Control
- Stick welding capability
- 7500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible
| Max Inrush Amps (I1Max) | 120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 29 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 17 A
| LCD Screen | No
| Memory | No
| Fan | On-Arc
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/15V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 100A/14V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 80A/13.2V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 185A/17.4V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 145A/15.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 110A/14.4V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 15.0 Volts
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 15.0 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 185 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 17.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 185 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.8 to 17.4 Volts
| Open Circuit Voltage (OCV) | 74V
| Start Amp Range AC | Fixed
| Start Amp Range DC | Fixed
| End Amp Range AC | Fixed
| End Amp Range DC | Fixed
| Pre-Flow Time | Fixed
| Up-Slope Time | Fixed
| TIG Pulse | AC
| AC Pulse Type | Standard
| DC Pulse Frequency | 1 or 50 Hz
| AC Pulse Frequency | 1 or 50 Hz
| Pulse Time-On (Balance/ Duty Cycle) | Fixed
| AC Frequency | 20-250 Hz
| AC Balance | 10-90% of Positive Electrode
| AC Wave Forms | Square
| Other Functions | Dual Voltage
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 150A/26V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 120A/24.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 90A/23.6V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 24.0 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 150 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 26.0 Volts
| Hot Start | Fixed
| Hot Start Time | Fixed
| Arc Force | Fixed
| Anti-Stick Protection | No
| Output | AC/DC
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 1/8"
Use 6011 for best results
| Important Stick Specification Notes | Not for E6010 use.
.007" to 3/16"
.007" to 3/16"
.025"- 3/16"
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical, recommended single pass limit based on the industry standard of performing thicker welds with multiple passes.
1/16"- 1/8"
- NOVA 17 Series Air-Cooled Rigid-Neck TIG Torch 12.5 Ft. 35 DINSE-Type Connector (No Gas Thru)
- 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- 240V-120V Pig Tail Adapter
- Consumable Starter Kit (No Tungsten)
