PowerTIG 325EXT (3Ph 480V)
SKU# PT-325EXT-480
- Unit Weight: 64 lb
- Unit Dimensions: 9.25 in × 25 in × 15 in
Built for professional fabrication, production and repair, the PowerTIG 325EXT combines serious welding power with precise control. Its digitally controlled IGBT inverter delivers up to 320A of AC/DC TIG output at a 35% duty cycle, with 480V three-phase operation for a wide range of shop applications. (This is only for use with 480V 3 phase power)
For aluminum welding, four AC waveforms—Advanced Square, Soft Square, Triangular and Sine—combine with adjustable AC balance and frequency up to 250 Hz to tailor the arc to the job. Advanced AC Pulse increases penetration on thicker aluminum, while standard pulse up to 500 Hz in DC and 250 Hz in AC helps manage heat on thinner materials.
Straightforward controls, Easy Start Up modes and programmable memory simplify setup and repeat work. Electronic HV arc starting eliminates traditional point-gap maintenance, while Fan-On-Demand automatically manages cooling during and after welding.
The 325EXT also delivers up to 250A of DC Stick output, with adjustable hot start and arc force to fine-tune starting and welding performance. From detailed TIG work to heavier fabrication and everyday repairs, it gives professionals the power and versatility to take on more.
Key Features
- Operates on 480V 3 phase for versatile performance options
- 5A DC Start and 10A AC Start for excellent arc starts on thinner materials
- Smooth, stable arc in TIG delivers a higher quality weld
- Solid state HV Start removes the issue of point gap maintenance for traditional HF starting
- 60% Duty cycle at maximum ouput, regardless of phase the unit is operated on extends operation times for true industrial settings
- Advanced AC pulse increases range of AC TIG performance by using a mixed/hybrid AC and DC negative pulse for maximum penetration
- 4 Adjustable AC Wave Forms: Advanced Square, Soft Square, Triangular and Sine Wave for improved Aluminum welding control
- Fan-on-arc for quieter operation
- 13,000 Surge Watts on 480V 3 phase
- E6010 mode operates best with a short arc
| Voltage/Phase | 480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 480V 3 Phase 50/60Hz: 14 A
| Rated Effective Amps (I1Eff) | 480V 3 Phase 50/60Hz: 9 A
| LCD Screen | No
| Memory | 9 Programs
| Fan | On-Arc
| TIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 320A/22.8V Rated Output
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 325 Amps
480V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
480V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 325 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.8 Volts
| Open Circuit Voltage (OCV) | 88V
| Start Amp Range AC | 10-320A
| Start Amp Range DC | 5-320A
| End Amp Range AC | 10-320A
| End Amp Range DC | 5-320A
| Post-Flow Time | 0-50 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Advanced
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
Sine
| Stick Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 250A/30V Rated Output
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 160A/26.4V Rated Output
| Stick Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 250 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 30 Volts
| Open Circuit Voltage (OCV) | 88 (<24 with VRD)V
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
| Maximum Stick Rod Diameter (Recommended, may vary by mfgr. and type) | 5/32"-3/16"
| E6010/Cellulose Rod (Electrode) Capable | Use 6011 for best results
Yes, but limited to short arc
| Important Stick Specification Notes | E6010 results may vary with rod manufacturer. Keep a short arc or drag rod for best performance.
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32"
- Aerospace
- Rail Car Industry
- 6.5 Ft. Power Input Cable (Power Plug not included)
- TIG Starter Consumable Kit
