PRO Gas Lens TIG Kit
Everlast TIG Consumable Kits
$159.00
SKU# EV-PRO-GL-V2-1
This PRO Gas Lens TIG Kit is designed to fit all 9, 20, 17, 18 and 26 series TIG torches.
The clear quality gas lens kits are high quality and are durable with reinforced with stainless surrounds. These are for day-in and day-out use for welding draft sensitive metals. The design improves laminar gas flow and helps to reduce gas waste while improving weld quality. The large design improves visibility and allows tungsten to be used with increased stickout without risking oxidation.
Includes the following:
- (1) Foam Lined Protective Box
- (1) # 12 Clear Champagne lens/nozzle with stainless surround, gas adapter, o-ring and diffusor screen: 54NQCN-15
- (1) # 14 Clear Champagne lens/nozzle with stainless surround, gas adapter, o-ring and diffusor screen: 54NQCN-14
- (1) # 16 Clear Champagne lens/nozzle with stainless surround, gas adapter, o-ring and diffusor screen: 54NQCN-16
- (1) # 24 Clear Champagne lens/nozzle, with stainless surround, gas adapter, o-ring and diffusor screen: 54NQCN-24
- (2) 9/20 3/32" Short Gas lens 4GL332
- (2) 17/18/26 3/32" Short Gas lens 4GL332
- (2) 9/20 3/32" Wedge Collet 4C332GS
- (2) 17/18/26 3/32" Wedge Collet 4C332GS
- (2) 9/20 Insulator 18CG20GS
- (2) 17/18/26 Insulator 18CG20GS
- (2) 3/32" 2% Blue Lanthanated Tungsten
Steel and Titanium applications
