PTM-60 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector
SKU# EV-PTM60-25C
- Unit Weight: 7 lb
- Shipping Weight: 11 lb
- Unit Dimensions: 24 in × 24 in × 3 in
The PTM 60 is a non-contact, blow back start style 60A rated machine torch with pilot arc designed for CNC and Automated cutting. Fits all Everlast plasma cutters with a Euro Central Connector. Natively fits PowerPlasma 50S, 52i, 60S, and 62i plasma cutters. It can be used on other units, but the maximum power is not to exceed 60 Amps. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-60A in capacity (.6-1.1mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
| Torch Amperage Rating | 60 Amps
| Torch Duty Cycle @ Amperage Rating | 100%
| Torch Connector Type | Euro-Central Connector
| Cooling Type | Air-Cooled
| Cable Length | 25 Ft.
