PTM-80 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector, view 1
PTM-80 CNC/Machine Torch Blow Back Start 25 Ft. Central Connector, view 2
SKU# EV-PTM80-25C
Blow-Back/Non HF
$579.00
Blow-Back/Non HF
SKU# EV-PTM80-25C
  • Unit Weight: 7 lb
  • Shipping Weight: 12 lb
  • Unit Dimensions: 24 in × 24 in × 3 in
The PTM 80 is a non-contact, blow back start style 80A rated machine torch with pilot arc designed for CNC and Automated cutting. Fits all Everlast plasma cutters with a Euro Central Connector. Natively fits PowerPlasma 80S, and 82i plasma cutters. It can be used on other units, but the maximum power is not to exceed 80 Amps. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-80A in capacity (.6-1.2/1.4mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
Torch Amperage Rating
80 Amps
Torch Connector Type
Euro-Central Connector
Cooling Type
Air-Cooled
Cable Length
25 Ft.
