RedSabre 1300, view 1
RedSabre 1300, view 2
RedSabre 1300, view 3
RedSabre 1300, view 4
RedSabre 1300, view 5
RedSabre 1300, view 6
RedSabre 1300, view 7
SKU# EV-LRS-1300
RedSabre 1300
$8,999.00
$7,999.00
Save - $1,000.00
RedSabre 1300
SKU# EV-LRS-1300
  • Unit Weight: 66 lb
RedSabre 1300
The new RedSabre 1300 is a table-top model, which makes it the perfect compact air-cooled laser for portable operations. The air cooled design of the RedSabre is a new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weigh over 3 to 4 times more. The high volume fan and high temperature diode design of the RedSabre 1300 reduces the footprint of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line. This model can Weld, Cut, and descale rust and paint.
Includes built-in touch screen color LCD controls. Wire Feeder now included.
Notice:
FDA Accession #: 2420545-000
FDA Product Code: 95R--FF
Gun Model Type
SUP33T
Cooling
Air-Cooled
Optic Pump Manufacturer
GW
