RedSabre 1500, view 1
RedSabre 1500, view 2
RedSabre 1500, view 3
RedSabre 1500, view 4
RedSabre 1500, view 5
RedSabre 1500, view 6
RedSabre 1500, view 7
RedSabre 1500, view 8
RedSabre 1500, view 9
SKU# EV-LRS-1500
RedSabre 1500
$12,774.00
$9,999.00
Save - $2,775.00
RedSabre 1500
SKU# EV-LRS-1500
  • Unit Weight: 181 lb
RedSabre 1500
The new RedSabre 1500 is a 1500 Watt, air cooled portable laser welder designed for compact size and portability. The air cooled design of the RedSabre is a new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weighing 600 lbs or more. The high volume fan and high temperature diode design of the RedSabre 1500 reduces the footprint of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line. This model can Weld, Cut, and descale rust and paint.
Includes detachable touch screen color LCD controls and synchronizing wire feeder.
Notice:
FDA Accession#: 2410134-000
FDA Product Code: 95R--FF
Gun Model Type
SUP33T
Optic Pump Manufacturer
RLASER
