RedSabre 1500X, view 1
RedSabre 1500X, view 2
RedSabre 1500X, view 3
RedSabre 1500X, view 4
RedSabre 1500X, view 5
RedSabre 1500X, view 6
RedSabre 1500X, view 7
RedSabre 1500X, view 8
RedSabre 1500X, view 9
SKU# EV-LRS-1500X-2
RedSabre 1500X
$9,999.00
$8,999.00
Save - $1,000.00
RedSabre 1500X
SKU# EV-LRS-1500X-2
  • Unit Weight: 345 lb
RedSabre 1500X
Laser technology is beginning to revolutionize the welding industry. Laser applications in the welding industry are evolving so fast that many major welding companies are having a hard time keeping up with it However, the need to stay current with Laser technology is clear because it has become not only become affordable, it changes in design and manufacturing of lasers have made them compact and practical even for small operations. Even so, some welding manufacturers have been slow or reticent to accept the new applications of Laser technology in the welding industry. However, in keeping with the heart of Everlast's policies to lead the way in the industry, Everlast has taken the lead by releasing a full scale production line with more laser related welding equipment than any other welding brand.
With the evolution of lasers and developments made in compact Fiber lasers, it has become very clear that Fiber Lasers are the future for precision welding of light to medium gauge metals. The pinpoint accuracy and speed at which a Fiber Laser can weld is stunning. New developments in technology have also improved ergonomics and durability of the hand held laser guns and related equipment. Compared to old CO2 lasers, Fiber lasers are "light years" ahead.
New developments in fiber laser technology allows one machine to expertly handle many other welding related processes without adding a lot of extra machines or equipment. The RedSabre 1500X can weld, cut, and descale rust and paint with one machine, making a truly versatile multi-process machine. No extra purchases are necessary to do so. It includes all the attachments and lenses needed to adapt the machine to the process desired. The programming allows for Cutting, cleaning, passivation, and welding without any special updates or upgrades to the machine. All you will need to do is provide, filler wire (MIG type) shielding gas or compressed air (depending upon the process) to support the desired process.
The ergonomic gun is compact and powerful with a fatigue reducing gun handle angle and a molded grip.
Notice:
Laser Processes
Weld
Clean/Derust
Weld Clean
Cut
Gun Model Type
SUP33T
Gun Operation and Programming
Single Scan
Maximum Wattage Output
1500W
Cooling
Refrigerated
Wire Feed Included
Wire Feeder Type
Single Spool
Optional Feeder Type
Double Spools
Class Laser
4
Optic Pump Manufacturer
GW
Minimum & Maximum:
  1. Maximum Weld Mild/Stainless Steel: 4.0mm (Single Pass)
  2. Maximum Weld Aluminum: 3.5 mm (Single Pass)
  3. Maximum Weld Copper: 2.0 mm (Single Pass)
  4. Maximum Cut Steel: 5.0 mm (Single Pass)
  5. Maximum Cut Aluminum: 4.0 mm (Single Pass)
  • Nozzle Kit
  • Wire Guide Tip Kit
  • Wire Feed Tubes
  • FT80 Focus Tube
  • D18T2 Protective Lens Kit
  • F800 Focus Lens
  • Single Liner Bracket Arm
  • Gas line (customer provides their own 1/4 in barb fitting)
  • Communication Cable
  • Door Safety Switch
  • Allen Wrench Set
  • Wrenches
  • Laser Safety Goggles
  • Laser Safety Face Shield
