RedSabre 2000, view 1
RedSabre 2000, view 2
RedSabre 2000, view 3
RedSabre 2000, view 4
RedSabre 2000, view 5
RedSabre 2000, view 6
RedSabre 2000, view 7
RedSabre 2000, view 8
RedSabre 2000, view 9
RedSabre 2000, view 10
SKU# EV-LRS-2000-1
RedSabre 2000
$12,499.00
$11,250.00
Save - $1,249.00
RedSabre 2000
SKU# EV-LRS-2000-1
  • Unit Weight: 207 lb
  • Unit Dimensions: 18 in × 32 in × 32 in
RedSabre 2000
The new RedSabre 2000 is a 2000 Watt, air cooled portable laser welder designed for compact size and portability. The air cooled design of the RedSabre is a new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weighing 600 lbs or more. The high volume fan and high temperature diode design of the RedSabre 2000 reduces the footprint of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line. This model can Weld, Cut, and descale rust and paint.
Includes detachable touch screen color LCD controls and synchronizing wire feeder.
For Manual use only. Not intended for automatic or computer controlled applications.
Notice:
Gun Model Type
SUP33T
Laser Processes
Weld
Clean/Derust
Weld Clean
Cut
Gun Operation and Programming
Single Scan
Maximum Wattage Output
2000W
Cooling
Air-Cooled
Wire Feed Included
Wire Feeder Type
Single Spool
Optional Feeder Type
Double Spools
Class Laser
4
Optic Pump Manufacturer
RLASER
Minimum & Maximum:
  1. Maximum Weld Mild/Stainless Steel: 6.0mm (Single Pass)
  2. Maximum Weld Aluminum: 4.5 mm (Single Pass)
  3. Maximum Weld Copper: 3.00 mm (Single Pass)
  4. Maximum Cut Steel: 6.0 mm (Single Pass)
  5. Maximum Cut Aluminum: 5.0 mm (Single Pass)
Weld/Cut Specifications (fractional values are rounded to nearest equivalent common sheet/plate value):
  1. Gap Fill (Root) w/o Wire: 1.0mm/.040"
  2. Gap Fill (Root) Single Wire Feeder 1.6mm/.062" (≤1/16")
  3. Gap Fill (Root) Double Wire Feeder 2.0mm/.080" (≤ 5/64")
  4. Single Side Weld Steel/S.S. Max: 6.0mm/ .24" (≤ 1/4")
  5. Single Side Weld Aluminum Max: 4.5mm/.18" (≤ 3/16")
  6. Single Side Weld Copper Max: 3.0mm/.12" (≤ 1/8")
  7. Cut Thickness Steel Max: 6.0mm/.24" (≤ 1/4")
  8. Cut Thickness Aluminum Max: 5.0mm/ 20" (≤7/32")
  • Nozzle Kit
  • Wire Guide Tip Kit
  • Wire Feed Tubes
  • FT80 Focus Tube
  • D18T2 Protective Lens Kit
  • F800 Focus Lens
  • Single Liner Bracket Arm
  • Gas line (customer provides their own 1/4 in barb fitting)
  • Communication Cable
  • Door Safety Switch
  • Allen Wrench Set
  • Wrenches
  • Laser Safety Goggles
  • Laser Safety Face Shield
