RedSabre 2000X, view 1
RedSabre 2000X, view 2
RedSabre 2000X, view 3
RedSabre 2000X, view 4
RedSabre 2000X, view 5
RedSabre 2000X, view 6
RedSabre 2000X, view 7
RedSabre 2000X, view 8
SKU# EV-LRS-2000X
RedSabre 2000X
$13,999.00
$12,099.00
Save - $1,900.00
RedSabre 2000X
SKU# EV-LRS-2000X
  • Unit Weight: 300 lb
RedSabre 2000X
Up until recently 2000 Watt fiber lasers were all water-cooled. This meant having large, bulky equipment to move around, sometimes weighing in excess of 750 lbs. However, concepts and applications of new technologies and developments in existing technologies have allowed the size and weight to be drastically reduced for this size of welder. The new RedSabre 2000 employs a novel method of cooling compared to the water cooled design: refrigeration. The refrigerated design reduces size and weight while improving cooling so that the units can run non stop for up to 12+ hours.
The ergonomic SUP33T gun is compact and powerful with a fatigue reducing gun handle angle and a molded grip.
Notice:
Gun Model Type
SUP33T
Cooling
Refrigerated
Optic Pump Manufacturer
GW
