RedSabre 300CP
SKU# EV-LRS-300CP-240
- Unit Weight: 65 lb
- Unit Dimensions: 9 in × 24 in × 17 in
The 300W Pulsed Wave Laser Cleaner can carefully remove paint and descale material with ease without damaging or overheating the subsurface. The Pulse wave laser design of the unit can be fine tuned for the precise amount of paint, mill scale and rust removal. The pulse action is more forceful than a standard non-pulse laser cleaner, so less wattage needs to be used. The unit can also select for cleaning width and cleaning pattern shapes, which are useful for improving cleaning efficiency on different textures and shapes.
This model features a compact steel portable case with na easy to use detachable touch screen control. This unit is ideal for use in auto body and small shop operations where compact size and portability are important.
Scan up to 160mm on the X axis and up to 120mm on the Y axis.
Note: at the maximum scan width settings, some cleaning efficiency may be lost.
| Gun Model Type | BWT30C
| Maximum Wattage Output | 300W
| Cooling | Air-Cooled
| Optic Pump Manufacturer | JPT
