RedSabre 550
SKU# EV-LRS-550
- Unit Weight: 62 lb
The new RedSabre 550 is a table-top model, which makes it the perfect compact air-cooled laser for portable operations. The air cooled design of the RedSabre is a new and innovative way to cool lasers without heavy, large water cooling systems. Many Fiber lasers in this wattage range are heavy water-cooled lasers weigh over 3 to 4 times more. The high volume fan and high temperature diode design of the RedSabre 550 reduces the footprint of the welder. The ergonomic SUP33T gun design and safety features are hallmarks of the RedSabre model line.
Includes built-in touch screen color LCD controls.
Notice:
- The operation of all Lasers in the USA falls under FDA restrictions, guidelines and general regulations. Additional OSHA and ANSI regulations and standards applicable to laser welding/cleaning/cutting use and applications exist.
- This is a class 4 laser, the most dangerous category. Safety Training and special laser light shielding equipment is required to use lasers for any application. Laser light radiation can be harmful, even though the wave length is not visible to the naked eye.
- Use safety glasses only matched to the wave length of this unit. Other Specialized safety equipment is also required Do not use standard cutting shades or welding helmets while using this equipment. Use only safety eye and face wear rated for 1080 nm wave lengths.
- The purchase of this laser welder may require registration with your local and state governments. Please identify any registration issues and concerns before purchase. Please contact your local and state governing authorities before purchase to inquire about registering your laser welders. Everlast does not maintain a list for each state, nor lists of general requirements for registration.
- The use of a laser in your business may require you to follow additional ANSI guidelines separate from the use of regular arc welders. It may also require special training and certifications that require additional investment and costs. In businesses with employees, you may be required to appoint a Laser Safety Officer with completed training and certification and additionally train individual operators and nearby individuals in laser safety and use.
- Contact independent laser safety certification companies for details and pricing of training. Most companies offer online certification, with some offering in person training as well. Prices vary for certification.
- Check with your insurance company to make sure that the use of a laser welder in your facility is covered if training and certifications are in place.
FDA Accession #: 2420545-000
FDA Product Code: 95R--FF
| Gun Model Type | SUP33T
| Gun Operation and Programming | Single Scan
| Cooling | Air-Cooled
