RedSabre Single Spool Laser Wire Feeder SUP-AMF-A, view 1
RedSabre Single Spool Laser Wire Feeder SUP-AMF-A, view 2
SKU# EV-SUP-AMF-AS
Single Spool Laser Wire Feeders
$829.00
$799.00
Save - $30.00
SKU# EV-SUP-AMF-AS
  • Unit Weight: 40 lb
  • Shipping Weight: 44.99 lb
  • Unit Dimensions: 10 in × 22 in × 14 in
The RedSabre Single Spool Wire feeder is designed to work seamlessly with all RedSabre Laser Welders. The compact size allows the feeder to be placed conveniently where it is needed. It can stack on top of most RedSabre units 1250 Watts and larger. The 4 roll drive system allows the unit to reliably feed wire to the laser torch head without issues. The digital screen offers full control of wire feed function. It has wire feed delay start to coordinate with the timing of the laser to be able to give the time for the puddle to develop. It also has a wire retract function to prevent the wire from starting in a cold puddle. The RedSabre Single Wire feeder works with the laser system and coordinates wire delivery so that consistent and high quality welds are easily achievable with minimal training.
This unit includes control cable and wire tubes for immediate setup.
Specific technical information not listed in specifications:
Power Input: 240V
Input Wattage: 60W
Input Amps: 2.5A
Wire Speed Adjustment Range: 15-600 cm/min or 6- 236 IPM (display is in cm/min)
Standard Wire Size Range:
Steel, Stainless V Type Groove: .8-1.6 mm (.030 to 1/16")
Aluminum U Type Groove: .8-1.6 mm (.030 to 1/16")
Maximum Wire Feed Speed
600 cm/min or 236 IPM
Maximum Spool Weight
44 lbs.
Spool Diameter(s)
12"
Number of Spools
One
Display
Full Digital Display
Number of Drive Rolls
Four
Drive Roll Sizes
.030"/.8mm
.035"/.9mm
.040-/ 1.0mm.045
.045" (.047 or 3/64")/1.2mm
.062" (1/16")/1.6mm
