S-45 Hand Held Plasma Torch Blow Back Start 15 Ft. Threaded Connector, view 1
S-45 Hand Held Plasma Torch Blow Back Start 15 Ft. Threaded Connector, view 2
SKU# EV-S45-15T
Blow-Back/Non HF
$149.00
Blow-Back/Non HF
SKU# EV-S45-15T
  • Unit Weight: 6 lb
  • Shipping Weight: 9 lb
The S-45 is a non-contact, blow back start style 40-50A rated torch with pilot arc designed for hand cutting. Natively fits older PowerPro, PowerUltra TIG, Stick, Plasma units with 50A or less plasma rating and threaded connection. Reuse the 35 Dinse Connector on the old torch or a new one may be found and purchased under the "Parts" tab. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-50A in capacity (.6-1.0mm orifice). This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
Torch Amperage Rating
50 Amps
35%
Torch Connector Type
Threaded Connector
Cooling Type
Air-Cooled
Cable Length
15 Ft.
