S-75 Trafimet® Hand Torch Blow Back Start 25 Ft. Central Connector
Blow-Back/Non HF
$389.00
Blow-Back/Non HF
SKU# TR-S75-25C
- Unit Weight: 7 lb
- Shipping Weight: 11 lb
- Unit Dimensions: 20 in × 20 in × 3 in
The S-75 Trafimet® is a non-contact, blow back start style 80A rated torch with pilot arc designed for hand cutting. Natively fits PowerPlasma S series multi-process units with the Euro Central connector. New connectors are located under the parts category. Consumables should be changed to fit the Amperage. Can be fitted with consumables ranging from 20-80A in capacity. This type of torch uses the consumable shoulder to initiate the arc by "blowing back" the spring loaded consumable with air pressure during start to strike an arc. (This is the standard type start for most modern plasma cuttings systems under 150A.)
| Torch Amperage Rating | 70 Amps
| Torch Connector Type | Euro-Central Connector
| Cooling Type | Air-Cooled
| Cable Length | 25 Ft.
