Skyliner 400S, view 1
Skyliner 400S, view 2
Skyliner 400S, view 3
SKU# SKYL-400S-240-480
Skyliner 400S
$1,599.00
$1,399.00
Save - $200.00
Skyliner 400S
  • Unit Weight: 65 lb
  • Shipping Weight: 79 lb
  • Unit Dimensions: 9.75 in × 26 in × 15 in
Skyliner 400S
The Skyliner 400S is built for demanding stick welding and carbon arc gouging. Its straightforward controls focus on the work at hand, delivering up to 315A with 240V single-phase input or 400A with 480V three-phase input.
For stick welding, it handles E6010 and a wide range of other electrodes. Adjustable Arc Force and Hot Start give you more control over arc performance, making the Skyliner 400S a capable choice for field work. For carbon arc gouging, pair it with an air compressor sized to meet the demands of the job.
Key Features
  1. Gouge Rated
  2. E6010 Capable
  3. One phase 240V
  4. Three phase 480V
15,500 Watts Surge Rating 240V 1 phase
20,000 Watts Surge Rating 480V 3 phase
Gouging Compressor Requirements: Gouging operation requires a large air compressor to gouge properly. You will need at least 35 CFM output at 90 PSI for sustainable operation. 40CFM or higher is best.
480V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 63 A
480V 3 Phase 50/60Hz: 23.4 A
240V 1 Phase 50/60Hz: 49 A
480V 3 Phase 50/60Hz: 19 A
Stick Duty Cycle 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
Stick Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/36V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/32.6V Rated Output
Stick Output Range 240V 1 Phase 50/60Hz
240V 1 Phase 50/60Hz Stick Amp DC Output Range: 20 to 315 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 32.6 Volts
Stick Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz Stick Amp DC Output Range: 20 to 400 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.8 to 36 Volts
90V
Hot Start
Adjustable
Hot Start Time
Fixed
Arc Force
Adjustable
Voltage Reduction (VRD)
Anti-Stick Protection
Stick Pulse
Functions with Remote
PowerSet Simplified Pro Setup
Carbon Arc Capable
1/4"
Maximum Carbon Arc Diameter
1/4"
Recommended Range of Welding Rod Diameters*:
1/16"- 3/16" (up to 1/4" on some rod types and brands)
*Range of welding rod diameters is based on welding rod type and manufacturer's actual recommendations. Always consult manufacturer's recommendations for Amp range and minimum/maximum welding capability of each rod type.
Recommended Maximum Size of Carbon Arc Electrode for Gouging:
1/4"
  • Rail Car Industry
  • Pipe and Structural
  • Repair and Fabrication
  • Air-Carbon Arc Torch with cable and 35 Series DINSE connector
  • 400A Work Clamp with 9 Ft. Cable and 35 Series DINSE connector
  • 300A Stick Electrode Holder with 10 Ft Cable and 35 Series DINSE connector
