TIG Button™  Amp Control Fits CK®/ Mr. TIG MT200 with 5 Pin Connector 25 Ft., view 1
SKU# EV-TBS-S-CK-5
$285.00
SKU# EV-TBS-S-CK-5
  • Unit Weight: 1 lb
  • Shipping Weight: 2 lb
This button fits CK/ Mr. TIG MT200 models.
Connector PIN Count
5
Cord Length
25 Ft.
