TIG Button™ Amp Control Fits Everlast® MTS/MTS-C welders with 7 Pin Male Connector 25 Ft.
SKU# EV-TBS-S-EVM-7
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Everlast® models with a 7 pin female connector
PowerMTS
Thunder
Lightning
Hurricane
| Connector PIN Count | 7 pin small male
| Cord Length | 25 Ft.
