TIG Button™ Amp Control Fits Miller® Syncrowave 250 with 5 Pin Connector 25 Ft.
SKU# EV-TBS-S-ME-5
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Miller® models with a 5 pin connector:
Syncrowave 250
| Connector PIN Count | 6
| Cord Length | 25 Ft.
