TIG Button™ Amp Control Fits Most Miller® TIGs with 14 Pin Connector 25 Ft.
SKU# EV-TBS-S-ME-14
- Unit Weight: 1 lb
- Shipping Weight: 2 lb
This button fits the following Miller® models with a 6 pin connector:
Dynasty
Syncrowave
Maxstar 200 and up
| Connector PIN Count | 6
| Cord Length | 25 Ft.
