Typhoon 330 (3Ph 480V), view 1
Typhoon 330 (3Ph 480V), view 2
Typhoon 330 (3Ph 480V), view 3
Typhoon 330 (3Ph 480V), view 4
Typhoon 330 (3Ph 480V), view 5
SKU# TY-330-480
Digital AC/DC
$3,250.00
$3,100.00
Save - $150.00
Digital AC/DC
SKU# TY-330-480
  • Unit Weight: 62 lb
  • Unit Dimensions: 9.5 in × 26 in × 15 in
Built for professionals who demand power and precise arc control, the Everlast Typhoon 330 with 3Ph 480V input puts advanced TIG performance at your fingertips. Part of Everlast’s top-tier TIG lineup, it delivers 330A of AC/DC TIG output at a 40% duty cycle.
The large 5.1-inch HD color LCD keeps your welding parameters visible on one screen, making settings easy to see, select, and adjust. Straightforward controls simplify setup and put even the machine’s most advanced functions within easy reach.
For aluminum welding, five AC waveforms—Advanced Square, Soft Square, Triangular, Sine, and Trapezoid—give you more ways to shape the arc. Independent positive and negative amperage adjustments let you fine-tune AC output, while split waveform control allows you to choose a different waveform for each half of the AC cycle. Add adjustable AC frequency up to 400Hz, and you have the flexibility to tailor the arc to your application and welding style.
Advanced AC Pulse blends AC with DC negative to increase penetration on thicker aluminum. For thinner materials and heat-sensitive work, adjustable DC pulse waveforms, DC pulse frequencies up to 999.9Hz, and standard AC pulse frequencies up to 400Hz provide precise control over heat input.
AC/DC Stick capability expands the Typhoon’s versatility for fabrication and repair. Its smooth, stable DC arc is well suited to E7018 and similar electrodes, with E6010 support. Adjustable AC Stick parameters provide additional control over penetration and travel speed.
  1. 3Ph 480V input
  2. AC/DC Pulse TIG with AC/DC Stick Output sets the standard for features and adjustability
  3. Low Amp Start of 2A DC and 3A AC for stable, easy starting with small diameter tungstens
  4. 5.1" 720 HD TFT screen allows easy viewing of parameters with high contrast graphics that can be viewed at a distance
  5. See and adjust all parameters on main screen without the bottle neck created by hidden pop-up menus
  6. High duty cycle operation at 40% @ maximum 330A output leads the industry
  7. Independent Amplitude Control on AC allow the Tungsten to last longer and improves penetration
  8. Single and Double Pulse DC TIG for maximum heat control and steady arc
  9. Standard AC and Advanced AC TIG (Mixed) Pulse
  10. Industry leading 5 AC wave forms with ability to assign individual half-wave forms with a total of 15 possible combinations, not including the unique wave form possible when using the AC Advanced Pulse
  11. Fully adjustable low Amp HV starting with ability to select tungsten size for maximum precision starts
  12. Remote control with Stick for maximum control with pedal or slider
  13. Dedicated cooler outlet installed in rear for use with water-cooled torches
  14. Fan-on-Arc or Temp Control for quieter operation or select full time operation for heavy duty use
  15. Cooler-on-Arc or full time cooler control when used with optional cooler
  2. 16500 Surge Watts
  1. Unit is equipped with separate water cooler and wire less foot pedal power outlets
  2. Do not use the optional water cooler on 120V. Unplug the cooler before using on 120V.
  3. Do not plug any other device into the water cooler outlet or into the outlet intended for powering the wireless foot pedal.
480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 18 A
480V 3 Phase 50/60Hz: 12 A
5.1 inches
Type
TFT
Resolution
720
21S
30 Programs
Temperature Controlled
On-Arc
TIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 330A/23.2V Rated Output
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 270A/20.8V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 210A/18.4V Rated Output
TIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz TIG Amp AC Output Range: 3 to 330 Amps
480V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.1 to 23.2 Volts
480V 3 Phase 50/60Hz TIG Amp DC Output Range: 2 to 330 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 23.2 Volts
83V
TIG Start Type
Live Lift Start
Lift Start With Remote
Start Amp Range AC
3-330A
Start Amp Range DC
2-330A
End Amp Range AC
3-330A
End Amp Range DC
2-330A
0-30 Seconds
0-60 Seconds
0-30 Seconds
0-60 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
Triangular
Trapezoid
Sine
Double
DC Pulse Frequency
0-0-999 Hz
DC Double Pulse Frequency
0-9.9 Hz
AC Pulse Frequency
0-500 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
3-100% of Welding Amperage
AC Frequency
20-400 Hz
AC Balance
5-70% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Trapezoid
Sine
Other Functions
Fast Tack (Cold Weld Function) Spot and Stitch Timer
.003" to 1/2"
.003" to 1/2"
.005"- 7/16"
1/16"- 1/4"
  • Aerospace
  • Rail Car Industry
  • Pipe and Structural
  • Gunsmithing
Downloads
