Vortex 205 MIG Wire Feeder Single Spool, view 1
Vortex 205 MIG Wire Feeder Single Spool, view 2
Vortex 205 MIG Wire Feeder Single Spool, view 3
SKU# V-205
Single Spool MIG Wire Feeders
$899.00
$629.00
Save - $270.00
SKU# V-205
  • Unit Weight: 45 lb
  • Shipping Weight: 50 lb
  • Unit Dimensions: 11 in × 28 in × 16 in
The Vortex 205 wire feeder works with the Tempest 412 model. It is a standard-type non-pulse wire feeder, but features additional controls on the panel that are more than basic functions. The 4 Roller drive system is gear driven to ensure positive feeding. The feeder also supports spool gun and push-pull operation.
  1. 12" wire spool capacity
  2. Detachable feeder carries any where with carry handle
  3. Pivots on the native PowerCart 301 style welding carts for easy rotation in the direction of use without repositioning cart
  4. Push Pull or Spool Gun can be used with this feeder
  5. Both Volts and Amps display
  6. Wire Jog function for fast wire installation
  7. Purge gas function to prevent wasting wire while adjusting gas flow rate
  8. 4 roller gear driven cast aluminum feeder.
  9. Spool cover clam shell to protect wire from elements
  10. 825 IPM max feed rate
Maximum Wire Feed Speed
700 IPM
Amperage Rating
500 Amps
Duty Cycle @ Amperage Rating
100%
Maximum Spool Weight
44 lbs
Spool Diameter(s)
12"
Number of Spools
One
Display
Full Digital Display
Number of Drive Rolls
Four
Stock Feeder Drive Roll Sizes
.040-/ 1.0mm.045 .045" (.047 or 3/64")/1.2mm
.062" (1/16") /1.6mm
Supports Gun Types
Spool Gun
Air-Cooled Push Pull-Gun
Water-Cooled Push-Pull Gun
Air-Cooled Standard MIG Gun
Water Cooled Standard MIG Gun
Maximum Recommended Operation Distance from Power Source
75 Ft./Meters
Compatible With
Everlast
Main Case Material Type
Steel
Type of Operation (s)
Synergic
Manual
