Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 1
Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 2
Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 3
Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 4
Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 5
Cyclone 212i & SM200N-MTS Spool Gun (Bundle), view 6
SKU# CLN-212I-SM200N-MTS-BUNDLE-12N
MIG
$1,648.00
$1,249.00
Save - $399.00
MIG
  • Unit Dimensions: 9 in × 18 in × 13 in
This Cyclone 212i spool gun bundle package includes Everlast Cyclone 212i and the North SM200N-MTS spool gun. Everything included in the standard Cyclone 212i accessory package is also included in this package. This spool gun package allows use of the 4" spools for long distance wire feeding. The spool gun includes .035" aluminum U-groove drive roll. Order additional drive rolls for different sized aluminum and steel wires for the spool gun.
Includes:
  1. Cyclone 212i MIG/DC Stick/ DC Live Lift TIG welder
  2. Cyclone 212i accessory package
  3. North SM200N Spool Gun with 25 Ft Cable
  2. 10,500 Surge Watts
  1. This welder performs best with .030" and .035" and solid wire sizes. .045/.047" sizes work best with aluminum and gasless flux-cored wires. With .023 and .030" diameter steel or stainless wires, do not use with guns longer than 10 Ft.
  1. This welder is not recommended for Gas-Shielded Flux-Cored operation. Choose a larger machine such as the Cyclone 262i for this type of operation.
  1. Gasless Flux-cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 33 A
240V 1 Phase 50/60Hz: 40 A
120V 1 Phase 50/60Hz: 20 A
240V 1 Phase 50/60Hz: 20 A
4.3 inches
Type
TFT
Resolution
HD 720
30 Programs
240V 1 Phase 50/60Hz: 15% Duty Cycle @ 40°C at 230A/25.5V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 260 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 26.5 Volts
70V
0-5 Seconds
0-15 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.030”
.035”
2
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Other MIG Functions
Spot Stitch
Wire Feed Speed
120V: 400IPM 240V: 600IPM
Torch/Gun
24 Series 10 Ft. (North)
24 gauge to 5/16"
22 gauge to 5/16"
1/8-1/4"
1/16"- 5/32"
.015" to 1/4"
.015" to 1/4"
