Cyclone 262i, view 1
Cyclone 262i, view 2
Cyclone 262i, view 3
Cyclone 262i, view 4
Cyclone 262i, view 5
SKU# CLN-262i
Cyclone 262i
MIG
$1,575.00
$1,200.00
Save - $375.00
Cyclone 262i
MIG
SKU# CLN-262i
  • Unit Weight: 69 lb
  • Shipping Weight: 81 lb
Cyclone 262i
Compact and powerful, the Cyclone 262i delivers professional MIG, Stick and basic DC lift Start TIG performance for industrial fabrication while fitting comfortably in home garages and shops of any size. Its bright 4.3" TFT color display provides large, easy-to-read output settings, and a 50% MIG duty cycle at 275A helps keep work moving with fewer cool down interruptions.
Advanced MIG controls include automatic run-in, adjustable start and end wire feed speeds, crater filling, wire feed slope control for 2T/4T operation, adjustable inductance, Spot and Stitch timers, and pre- and post-flow gas control. For Stick welding, the Cyclone handles a broad range of electrodes, including E6010. Adjustable Arc Force, Hot Start, and Hot Start duration let you tailor performance to the electrode and welding position.
Setup is straightforward with intuitive controls and PowerSet, which automatically selects settings based on basic inputs such as wire size and material thickness. Available in both MIG and Stick modes, PowerSet helps beginners and professionals set up quickly. Multiple program memories let you save preferred settings for consistent, repeatable results.
The unit comes configured for .035" and .045" wire, with optional components available for sizes from .023" to .062".
  1. 240V input
  2. 4.3" HD TFT screen
  3. PowerSet mode for easy setup and reduced input
  4. Wire Jog and Gas Purge for easier wire installation and changeover
  5. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  6. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  7. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  8. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  9. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  10. Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
  11. Additional polymer liner, U-Groove drive roll and Spool Gun are optional
  2. 13500 Surge Watts
240V 1 Phase 50/60Hz: 52 A
240V 1 Phase 50/60Hz: 37 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/27.8V Rated Output
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
None
Spool Sizes
8”
12”
.035”
Steel V-groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Other MIG Functions
Spot Stitch
Wire Feed Speed
600 IPM
Torch/Gun
36 Series 10 Ft. (North)
Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
24 gauge to 3/8"
22 gauge to 3/8"
1/8-3/8"
1/16"- 3/16"
.015" to 3/8"
.015" to 3/8"
  • Aerospace
Downloads
