Cyclone 262i with Parker DSP 360A Spool Gun
SKU# CLN-262I-DSP360A-24
The Cyclone 262i Spool Gun package includes everything in the Cyclone 262i welder package plus the heavy-duty Parker DSP 360A spool gun with 24 Ft cable. This package works well for light and medium Aluminum welding. The gun comes with a .047" drive roll for welding 1/8" and thicker plate.
Includes:
- Cyclone 262i MIG/Stick/DC Lift TIG welder
- Cyclone 262i standard accessory kit
- Parker DSP 360A Spool Gun 24 Ft.
- 13,500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 52 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 37 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/27.8V Rated Output
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 600IPM
| Torch/Gun | 36 Series 10 Ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 230A/29.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 29.4 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/21V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 21 Volts
24 gauge to 3/8"
22 gauge to 3/8"
1/8-3/8"
1/16"- 3/16"
.015" to 3/8"
.015" to 3/8"
- Aerospace
- Parker DSP 360A Spool Gun 25 Ft. Euro Quick Connect
