Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 1
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 2
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 3
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 4
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 5
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 6
Cyclone 262i & Parker DSP 360 Spool Gun (Bundle), view 7
SKU# CLN-262I-DSP360A-24
MIG
$2,174.00
$1,750.00
Save - $424.00
MIG
The Cyclone 262i Spool Gun package includes everything in the Cyclone 262i welder package plus the heavy-duty Parker DSP 360A spool gun with 24 Ft cable. This package works well for light and medium Aluminum welding. The gun comes with a .047" drive roll for welding 1/8" and thicker plate.
Includes:
  1. Cyclone 262i MIG/Stick/DC Lift TIG welder
  2. Cyclone 262i standard accessory kit
  3. Parker DSP 360A Spool Gun 24 Ft.
  2. 13,500 Surge Watts
240V 1 Phase 50/60Hz: 52 A
240V 1 Phase 50/60Hz: 37 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 50% Duty Cycle @ 40°C at 275A/27.8V Rated Output
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
None
Spool Sizes
8”
12”
.035”
Steel V-groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Other MIG Functions
Spot Stitch
Wire Feed Speed
600IPM
Torch/Gun
36 Series 10 Ft. (North)
Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
24 gauge to 3/8"
22 gauge to 3/8"
1/8-3/8"
1/16"- 3/16"
.015" to 3/8"
.015" to 3/8"
  • Aerospace
  • 36 series MIG Gun 10 ft. with Euro Central Connector
  • Ground Clamp with 10 ft. cable and 35 Dinse Connector
  • Stick Electrode Holder with 10 ft. cable and 35 Dinse Connector
  • RH-191 Argon/CO2 Flowmeter Regulator with Hose
  • Drive Roll V Groove .035"-.045" (Double) (installed)
  • Drive Roll V Groove .023"-.030" (Double) (extra)
  • Spare M8 Contact Tips
  • Spool Adapter 8"
  • Parker DSP 360 Spool Gun (bundle only)
