Cyclone 263Pi, view 1
Cyclone 263Pi, view 2
Cyclone 263Pi, view 3
Cyclone 263Pi, view 4
Cyclone 263Pi, view 5
Cyclone 263Pi, view 6
SKU# CLN-263PI-240
Pulse MIG
$1,999.00
$1,649.00
Save - $350.00
Pulse MIG
SKU# CLN-263PI-240
  • Unit Weight: 70 lb
  • Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 263Pi is built for professionals who need the speed and productivity of a single Pulse MIG without giving up the control, versatility, and durability expected from a serious commercial welding machine. Its digitally controlled synergic technology and refined programming help simplify setup while delivering smooth, consistent arc performance across a wide range of applications.
With 275A of MIG output at a 60% duty cycle, the Cyclone 263Pi is designed for demanding fabrication, structural work, repair, and production environments. Dedicated settings for steel, stainless steel, aluminum, gas-shielded flux-cored, and gasless flux-cored wire give the operator the flexibility to move from one job to the next without changing machines. Fully synergic Pulse MIG provides excellent control over heat input and arc behavior while dramatically reducing spatter, helping produce clean, high-quality welds with less time spent on cleanup.
For aluminum work, the Cyclone 263Pi is ready for both optional spool guns and push-pull guns, making it well suited for applications where additional reach or more reliable aluminum wire feeding is needed.
And while single Pulse MIG capability may be one of its biggest strengths, the Cyclone 263Pi is far from a one-process machine. It performs equally well in conventional short-circuit and spray-arc MIG applications and comes equipped with a heavy-duty MIG gun designed to handle the heat and duty cycle the machine can deliver.
The Cyclone 263Pi also adds capable Stick and DC TIG performance for the jobs that call for something different. Its Stick mode supports E6010 and most common electrodes up to 5/32", with some electrode types supported up to 3/16". Basic, no frills Lift Start DC TIG rounds out the package for applications such as pipe work, construction, maintenance, and commercial steel fabrication where you need a "TIG-rig", pedal-less style of operation.
For the professional who wants one machine that can handle production work, structural fabrication, aluminum, field repair, and general shop use, the Cyclone 263Pi delivers a practical combination of power, control, and everyday versatility.
  1. 240V input
  2. 5.1" HD TFT screen
  3. Single Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
  4. PowerSet mode for easy setup and reduced input
  5. Wire Jog and Gas Purge for easier wire installation and changeover
  6. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  7. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  8. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  9. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  10. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  11. Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
  12. Additional polymer liner, U-Groove drive roll and Spool Gun are optional
  2. 13500 Surge Watts
240V 1 Phase 50/60Hz: 48 A
240V 1 Phase 50/60Hz: 38 A
5.1 inches
Type
TFT
Resolution
720 HD
21S
30 Programs
80V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1.0 Seconds
0-1.0 Seconds
2T SP
4T SP
MIG Pulse
Single
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
Wire Feeder Type
Internal/Self Contained Wire Feeder
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
Wire Feed Speed
600 IPM
Torch/Gun
36 Series 10 Ft.
This unit is Single Pulse only. It is not Double Pulse.
24 gauge to 1/2"
22 gauge to 1/2"
.045-7/16"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
  • Aerospace
Downloads
