Cyclone 263Pi & Cart 375LF & North MPG 300 Push Pull Gun (Bundle)
SKU# CLN-263Pi-375LF-MPG300
- Unit Weight: 70 lb
- Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 263Pi North MPG 300 Push-Pull Gun package includes everything in the Cyclone 263Pi welder package plus the heavy-duty North 300 MPG air-cooled push-pull gun with 25 Ft. cable. This package works well for all types of aluminum welding. This package also includes the NOVA PowerCart 375LF welding cart.
Includes:
- Cyclone 263Pi MIG/Stick/DC Lift TIG welder
- Cyclone 263Pi standard accessory kit
- North MPG 300 Push-Gun 25 Ft.
- NOVA PowerCart 375LF
- 13500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 48 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 38 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
2T SP
4T SP
| MIG Pulse | Single
| MIG Pulse Pinch Effect | No
| Spool Sizes | 8”
12”
| Wire Feeder Type | Internal/Self Contained Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | 36 Series 10 Ft.
| Important MIG Specification Notes | This unit is Single Pulse only. It is not Double Pulse.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 230A/29.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 230 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 29.2 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 250 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 20 Volts
| Important TIG Specification Notes | This is a basic DC Lift TIG. There is no pedal control, or remote amperage set. It is not designed to weld aluminum. Recommend a 17V gas valve torch for TIG RIG setup.
24 gauge to 1/2"
22 gauge to 1/2"
.045-7/16"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
- Aerospace
- 36 Series MIG Gun 3m 10 ft.
- Drive Roll Flux Core Double (Flux-Core Wire) – .045"-.062" (1.2-1.6mm)
- Drive Roll V-Groove Double (Steel/Stainless) – .023"-.030" (0.6-0.8mm)
- North MPG 300A Air-Cooled Push-Pull Gun Fits Everlast 25 Ft. Euro Quick Connect
- 6.5 Ft. Power Cord with NEMA 6-50 Plug
- Contact Tip M8 Thread
