Cyclone 273DPi Single and Double Pulse MIG with Parker SGP 360 Push-Pull Gun, view 1
Cyclone 273DPi Single and Double Pulse MIG with Parker SGP 360 Push-Pull Gun, view 2
SKU# CLN-273DPI-SGP 360-BUNDLE-13
Pulse MIG
$4,198.00
$3,800.00
Save - $398.00
Pulse MIG
  • Unit Weight: 70 lb
  • Unit Dimensions: 11.25 in × 28 in × 18 in
The Cyclone 273DPi Parker SGP 360 Push-Pull Gun package includes everything in the Cyclone 273DPi welder accessory package plus the heavy-duty Parker SGP a 273DPi air-cooled push-pull gun with 24 Ft. cable. This package works well for all types of aluminum welding.
Includes:
  1. Cyclone 263Pi MIG/Stick/DC Lift TIG welder
  2. Cyclone 263Pi standard accessory kit
  3. Parker Push-Pull SGP 360A 24 Ft.
  2. 13,500 Surge Watts recommended
  1. This welder ships with two 24 series MIG gun configured for a variety of welding needs. Heavy, sustained maximum amp welding may require a 36 series gun to be purchased. It comes with a red steel and a red polymer (for aluminum) liner for .040 and .045" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. So, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
  2. Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Do not feed aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun. Always use polymer liner for feeding aluminum. This may require a liner change. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
  3. Gasless Flux-cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 53 A
240V 3 Phase 50/60Hz: 26 A
240V 1 Phase 50/60Hz: 41 A
240V 3 Phase 50/60Hz: 21 A
5.1 inches
Type
TFT
Resolution
720 HD
21S
30 Programs
MIG Duty Cycle 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 275A/27.8V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/24V Rated Output
MIG Output Range 240V 3 Phase 50/60Hz
240V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 275 Amps
240V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.5 to 27.8 Volts
75V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1.0 Seconds
0-1.0 Seconds
2T SP
4T SP
MIG Pulse
Single and Double
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
Wire Feeder Type
Internal/Self Contained Wire Feeder
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
Wire Feed Speed
600 IPM
Torch/Gun
24 Series 10 Ft. x 2 plus Parker SGP 360 Push-Pull
This unit is Single Pulse and Double Pulse.
24 gauge to 3/8"
22 gauge to 3/8"
.045-3/8"
1/16"- 3/16"
.020" to 3/8"
.020" to 3/8"
  • Aerospace
