Cyclone 312i, view 1
Cyclone 312i, view 2
Cyclone 312i, view 3
Cyclone 312i, view 4
Cyclone 312i, view 5
Cyclone 312i, view 6
Cyclone 312i, view 7
MIG
SKU# CLN-312i
  • Shipping Weight: 79 lb
The Everlast Cyclone 312i is a professional, heavy-duty MIG/Stick welder ready for almost any work environment. It delivers up to 315A of MIG power and 250A of Stick power, with a 35% duty cycle at maximum output. Its compact inverter design and integrated undercarriage make it easy to move around the shop, while the bright 4.3" color display keeps settings easy to read.
PowerSet simplifies setup with recommended voltage and wire speed settings based on your gas, wire type, and wire size, with fine-tuning available for specific applications. Adjustable gas flow, inductance, and burnback help refine MIG performance, while 2T/4T controls and spot and stitch timers support long seams and consistent welds. Stick mode handles electrodes including E6010 and offers PowerSet settings for a variety of steel rods. Memory storage saves your preferred settings for both processes.
  1. 240V input
  2. 4.3" HD TFT screen
  3. PowerSet mode for easy setup and reduced input
  4. Wire Jog and Gas Purge for easier wire installation and changeover
  5. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  6. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  7. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  8. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  9. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  10. Can use spool gun or stock gun with polymer liner for Aluminum with U groove drive rolls
  11. Additional polymer liner, U-groove drive roll and Spool Gun are optional
  2. 16,500 Surge Watts
240V 1 Phase 50/60Hz: 64 A
240V 1 Phase 50/60Hz: 41 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 315 Amps
70V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
2T SP
4T SP
MIG Pulse
None
Spool Sizes
8”
12”
.035”
Steel V-groove
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Other MIG Functions
Spot Stitch
Wire Feed Speed
600IPM
Torch/Gun
36 Series 10 Ft. (North)
Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
24 gauge to 1/2"
22 gauge to 1/2"
1/8-7/16"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
  • Aerospace
Downloads
