Cyclone 312i Spool Gun and Cart Package
SKU# CLN-312I-DSP360A-375LF-BUNDLE-PP
- Shipping Weight: 79 lb
The Everlast Cyclone 312i Spool-gun and cart package is bundled with the Cyclone 312i, the Parker DSP 360A Spool Gun, and the NOVA PowerCart 375LF welding cart. This package includes all the accessories included in the Standard Everlast Cyclone 312i package, including the standard accessories. This package is ideal for light aluminum or steel fabrication where a longer welding distance is needed.
Includes:
- Cyclone 312i
- Cyclone 312i accessory package
- NOVA PowerCart 375LF
- Parker DSP 360 Spool Gun 25 Ft.
- 16,500 Surge Watts
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 64 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/29.8V Rated Output
| Up-Slope Time | 0-1 Seconds
2T SP
4T SP
| MIG Pulse | None
| Spool Sizes | 8”
12”
Steel V-groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Other MIG Functions | Spot
Stitch
| Wire Feed Speed | 600IPM
| Torch/Gun | 36 Series 10 Ft. (North)
| Important MIG Specification Notes | Purchase a separate liner for each wire size that will be used. For under 230A operation, purchase a 24 series gun.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 250A/30V Rated Output
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 40% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 22.6 Volts
24 gauge to 1/2"
22 gauge to 1/2"
1/8-7/16"
1/16"- 3/16"
.015" to 1/2"
.015" to 1/2"
- Aerospace
- Parker DSP 360A Spool Gun 25 Ft. Euro Quick Connect
