Cyclone 373DPi & North MPG 300 Push Pull Gun (Bundle)
SKU# CLN-373DPI-MPG300-BUNDLE
The Cyclone 373DPi builds on the proven reputation of the Power i-MIG 353DPi with more power, greater versatility, and intuitive color LCD controls that simplify setup. With standard MIG, Synergic Single Pulse, Double Pulse, and Flux-cored capabilities, it handles a broad range of fabrication and production work in steel, stainless steel, and aluminum, along with MIG brazing applications. PowerSET helps streamline setup, while improved Stick performance and basic DC TIG expand your options for repair and specialty work.
The separate wire feeder gives you flexibility in how you arrange your workspace. Keep it on the cart for a compact setup, or detach and position it closer to the work within the reach of the connecting cables. Its large color LCD panel provides direct control of all MIG functions and settings right at the feeder, reducing trips back to the power source. Capacity for wire rolls up to 12 inches supports longer welding runs and fewer spool changes.
For Stick welding, the Cyclone 373DPi supports E6010 and virtually any other welding electrode, making it a capable choice for demanding fabrication and repair jobs. Operation on either 240V single-phase or 480V three-phase input adds flexibility for different shop environments. Complete with a water cooler, water-cooled MIG gun, and cart, the Cyclone 373DPi brings a versatile welding system to your shop in one complete package.
- 240V 1 phase or 480V 3 phase input
- 370A @ 60% Duty Cycle all volts/phases for MIG operation
- 5.1" HD TFT screen on Feeder and 4.3" HD TFT screen on Power Source
- Single and Double Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
- Detachable wire feeder with a 15 ft. umbilical allows the feeder to be carried close to the work
- Push-Pull and Spool Gun capable.
- Weld and Braze with MIG
- Includes 510 series water cooled 15 ft. gun, steel and graphene liners, and drive rolls for steel and aluminum welding
- 13500 Surge Watts recommended
- This welder ships with a water-cooled SN-510 MIG Gun configured for heavy-duty welding (500A). It works well for .045" wire and larger in heavy duty applications. For lighter use,consistently under 250A, a 24 series gun may need to be considered for purchase.
- The SN-510 comes with .045" to .062" liners. Smaller liners are not offered at this time for this size of MIG gun.
- The graphene liner on the SN-510 gun is used for aluminum and is pre-installed. For smaller diameter wire, consider the 24 series under 250A. It has a red steel liner preinstalled and a red polymer (for aluminum) liner for .040 and .045" wire is optional. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. If heavy welding under 300 amp is done but water cooling isn't required, use the air-cooled 36 series gun. In any case, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
- Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Normally, we do not recommend feeding of aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun, even with a matched liner or feeding difficulties may be experienced. If a smaller wire must be fed, match the liner color to the wire size. Always use polymer liner for feeding aluminum. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
- Gasless Flux-cored operation is not recommended with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
- Do not use SN-510 water-cooled gun without the cooler. Gun warranty is voided if the gun is used without the cooler connected, and circulating water through the gun.
480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 62.5 A
480V 3 Phase 50/60Hz: 21.6 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 49 A
480V 3 Phase 50/60Hz: 18 A
| LCD Screen | 5.1 wire feeder/ 4.3 wire feeder inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 370A/32.5V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 290A/28.5V Rated Output
| MIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 370A/32.5V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 290A/28.5V Rated Output
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 370 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.75 to 32.5 Volts
| MIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 370 Amps
480V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.75 to 32.5 Volts
2T SP
4T SP
| MIG Pulse | Single
Double
| Spool Sizes | 8”
12”
| Wire Feeder Type | External Wire Feeder
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 700 IPM
| Torch/Gun | 510 Series Water-Cooled 15 Ft.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 350A/34V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 280A/31.2V Rated Output
| Stick Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 350A/34V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 280A/31.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 350 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 34 Volts
| Stick Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 350 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 34 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 350A/24V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 280A/21.2V Rated Output
| TIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 350A/24V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 280A/21.2V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 350 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 24 Volts
| TIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz TIG Amp DC Output Range: 10 to 350 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 24 Volts
| Important TIG Specification Notes | This is a basic DC Live Lift TIG. There is no pedal or remote control. Use with a "TIG rig" that includes a gas valve torch. Not for use with Aluminum
24 gauge to 1/2+"
22 gauge to 1/2+"
.045-1/2+"
1/16- 1/4"
.020" to 1/2'
.020" to 1/2"
- Aerospace
- Contact Tip M6 Thread .035" and .045"
- North MPG 300 Push Pull Gun (promo)
