Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 1
Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 2
Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 3
Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 4
Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 5
Cyclone 373DPi & Parker DSP 360 Spool Gun (Bundle), view 6
SKU# CLN-373DPI-DSP360-BUNDLE
Pulse MIG
$5,430.00
$4,550.00
Save - $880.00
Pulse MIG
The Cyclone 373DPi builds on the proven reputation of the Power i-MIG 353DPi with more power, greater versatility, and intuitive color LCD controls that simplify setup. With standard MIG, Synergic Single Pulse, Double Pulse, and Flux-cored capabilities, it handles a broad range of fabrication and production work in steel, stainless steel, and aluminum, along with MIG brazing applications. PowerSET helps streamline setup, while improved Stick performance and basic DC TIG expand your options for repair and specialty work.
The separate wire feeder gives you flexibility in how you arrange your workspace. Keep it on the cart for a compact setup, or detach and position it closer to the work within the reach of the connecting cables. Its large color LCD panel provides direct control of all MIG functions and settings right at the feeder, reducing trips back to the power source. Capacity for wire rolls up to 12 inches supports longer welding runs and fewer spool changes.
For Stick welding, the Cyclone 373DPi supports E6010 and virtually any other welding electrode, making it a capable choice for demanding fabrication and repair jobs. Operation on either 240V single-phase or 480V three-phase input adds flexibility for different shop environments. Complete with a water cooler, water-cooled MIG gun, and cart, the Cyclone 373DPi brings a versatile welding system to your shop in one complete package.
  1. 240V 1 phase or 480V 3 phase input
  2. 370A @ 60% Duty Cycle all volts/phases for MIG operation
  3. 5.1" HD TFT screen on Feeder and 4.3" HD TFT screen on Power Source
  4. Single and Double Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
  5. Detachable wire feeder with a 15 ft. umbilical allows the feeder to be carried close to the work
  6. Push-Pull and Spool Gun capable.
  7. PowerSet mode for easy setup and reduced input
  8. Wire Jog and Gas Purge for easier wire installation and changeover
  9. Basic DC Lift TIG function with optional gas valve TIG torch (TIG rig)
  10. Additional Stick welding function for welding with cellulosic (E6010), iron powder and titania rods
  11. The advanced PowerSet function reduces time and effort to set up the welder and yields satisfactory results
  12. The adjustable settings in PowerSet mode allow for plenty of adjustment to allow for different welding positions
  13. 12" and 8" wire spool capacity (10-12lbs. and 30-44lbs.)
  14. Weld and Braze with MIG
  15. Includes 510 series water cooled 15 ft. gun, steel and graphene liners, and drive rolls for steel and aluminum welding
  2. 13,500 Surge Watts recommended
  1. This welder ships with a water-cooled 500A 510 Series MIG configured for heavy-duty welding. It works well for .045" wire and larger in heavy duty applications. For lighter use,consistently under 250A, a 24 series gun may need to be considered for purchase.
  2. The 510 comes with .045" to .062" liners. Smaller liners are not offered at this time for this size of MIG gun.
  3. The graphene liner on the 510 gun is used for aluminum and is pre-installed. For smaller diameter wire, consider the 24 series under 250A. It has a red steel liner preinstalled and a red polymer (for aluminum) liner for .040 and .045" wire is optional. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. If heavy welding under 300 amp is done but water cooling isn't required, use the air-cooled 36 series gun. In any case, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
  4. Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Normally, we do not recommend feeding of aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun, even with a matched liner or feeding difficulties may be experienced. If a smaller wire must be fed, match the liner color to the wire size. Always use polymer liner for feeding aluminum. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
  5. Gasless Flux-cored operation is not recommended with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
  6. Do not use the 510 water-cooled gun without the cooler. Gun warranty is voided if the gun is used without the cooler connected, and circulating water through the gun.
480V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 62.5 A
480V 3 Phase 50/60Hz: 21.6 A
240V 1 Phase 50/60Hz: 49 A
480V 3 Phase 50/60Hz: 18 A
5.1 wire feeder/ 4.3 wire feeder inches
Type
TFT
Resolution
720 HD
21S
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 370A/32.5V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 290A/28.5V Rated Output
MIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 370A/32.5V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 290A/28.5V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 370 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 15.75 to 32.5 Volts
MIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 370 Amps
480V 3 Phase 50/60Hz MIG Volt DC Output Range: 15.75 to 32.5 Volts
82V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
MIG Hot Start Duration
Adjustable
MIG Crater Fill (End Fill)
Adjustable
Adjustable
0-10 Seconds
0-30 Seconds
0-1.0 Seconds
0-1.0 Seconds
2T SP
4T SP
MIG Pulse
Single
Double
MIG Pulse Pinch Effect
MIG Pulse Operation
Synergic
Spool Sizes
8”
12”
Wire Feeder Type
External Wire Feeder
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
Wire Feed Speed
700 IPM
Torch/Gun
510 Series Water-Cooled 15 Ft.
This unit is Single Pulse and Double Pulse.
24 gauge to 1/2+"
22 gauge to 1/2+"
.045-1/2+"
1/16- 1/4"
.020" to 1/2'
.020" to 1/2"
  • Aerospace
