Cyclone 573DPi Single and Double Pulse MIG
SKU# CLN-573DPI
Built for demanding fabrication and production work, the Cyclone 573DPi is the largest and most powerful model in Everlast’s Cyclone Synergic Single and Double Pulse MIG lineup. Building on the proven performance of its smaller siblings, it delivers more welding power than any other MIG welder in the Everlast lineup, with the versatility and control professionals need for heavy-duty applications.
Standard MIG, Synergic Single Pulse, Double Pulse, and Flux-Cored capabilities provide flexibility across a wide range of welding tasks. PowerSET simplifies setup, while enhanced Stick performance and basic DC TIG capability expand its usefulness throughout the shop. Intuitive color LCD screens make settings easy to view and adjust.
The separate wire feeder features a large color LCD screen with direct control of all MIG functions and processes, keeping adjustments close to the work. Supplied as a complete package with a water cooler, water-cooled MIG gun, and cart, the Cyclone 573DPi brings powerful performance and practical convenience to demanding industrial welding.
- 240V 1 phase or 480V 3 phase input
- 500A @ 60% Duty Cycle all volts/phases for MIG operation
- 5.1" HD TFT screen on Feeder and 4.3" HD TFT screen on Power Source
- Single and Double Pulse Synergic MIG with multiple wire/metal type selection for optimized performance
- Detachable wire feeder with a 15 ft. umbilical allows the feeder to be carried close to the work
- Push-Pull and Spool Gun capable.
- Weld and Braze with MIG
- Includes 510 series water cooled 15 ft. gun, steel and graphene liners, and drive rolls for steel and aluminum welding
- 22,000 Surge Watts recommended (single phase 240V)
- This welder ships with a water-cooled 500A 510 Series MIG configured for heavy-duty welding. It works well for .045" wire and larger in heavy duty applications. For lighter use,consistently under 250A, a 24 series gun may need to be considered for purchase.
- The 510 comes with .045" to .062" liners. Smaller liners are not offered at this time for this size of MIG gun.
- The graphene liner on the 510 gun is used for aluminum and is pre-installed. For smaller diameter wire, consider the 24 series under 250A. It has a red steel liner preinstalled and a red polymer (for aluminum) liner for .040 and .045" wire is optional. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A blue liner (.030–.035") is available for smaller wire. If heavy welding under 300 amp is done but water cooling isn't required, use the air-cooled 36 series gun. In any case, be sure to purchase additional liners to match the wire sizes you plan to use. In most cases .047" (aluminum) wire will be the best choice for all gauges of aluminum, thick or thin.
- Do not use .030" or smaller steel/stainless wire in a MIG gun longer than 12 feet. Normally, we do not recommend feeding of aluminum wire smaller than .047"/ 3/64" / 1.2mm through standard gun, even with a matched liner or feeding difficulties may be experienced. If a smaller wire must be fed, match the liner color to the wire size. Always use polymer liner for feeding aluminum. 4043 may not feed well through main gun. Use 4943 instead. It is the preferred 40XX series for replacing 4043 wire.
- Gasless Flux-cored operation is not recommended with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
- Do not use the 510 water-cooled gun without the cooler. Gun warranty is voided if the gun is used without the cooler connected, and circulating water through the gun.
480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 81.2 A
480V 3 Phase 50/60Hz: 32.4 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 63 A
480V 3 Phase 50/60Hz: 26 A
| LCD Screen | 5.1 wire feeder/ 4.3 wire feeder inches
| Type | TFT
| Resolution | 720 HD
| Memory | 30 Programs
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/34V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/30V Rated Output
| MIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 500A/39V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 400A/34V Rated Output
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 60 to 400 Amps
240V 1 Phase 50/60Hz MIG Volt DC Output Range: 17 to 34 Volts
| MIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz MIG Amp DC Output Range: 60 to 500 Amps
480V 3 Phase 50/60Hz MIG Volt DC Output Range: 17 to 39 Volts
2T SP
4T SP
| MIG Pulse | Single
Double
| Spool Sizes | 8”
12”
| Wire Feeder Type | External Wire Feeder
| Stock Drive Roll Wire Sizes Installed | .045” (.047 or 3/64”)
.062”
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Soft/EZ Start
Arc Trim (Pulse)
Spot
Stitch
| Wire Feed Speed | 700 IPM
| Torch/Gun | 510 Series Water-Cooled 15 Ft.
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/32.6V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
| Stick Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/36V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/32.6V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 315 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 32.6 Volts
| Stick Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 400 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 36 Volts
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 500A/30V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 400A/26V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 26 Volts
| TIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz TIG Amp DC Output Range: 10 to 350 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 24 Volts
| Important TIG Specification Notes | This is a basic DC Live Lift TIG. There is no pedal or remote control. Use with a "TIG rig" that includes a gas valve torch. Not for use with Aluminum
18 gauge to 1/2+"
18 gauge to 1/2+"
.062-1/2+"
1/16- 1/4"
.020" to 1/2+
.020" to 1/2+"
- Aerospace
- 500 A Bronze C-Clamp Work (Ground) Clamp with 10 Ft. Cable and DINSE 35 Connector
- Large Drive Roll U-Groove Double (Aluminum/Bronze) for External Feeders – .045"-.062" (1.2-1.6mm)
- Large Drive Roll V-Groove Double (Steel/Stainless) for External Feeders – .045"-.062"(1.2-1.6mm)
