Drive Roll Flux Core Single (Flux Core Wire)
SKU# EV-DR-FC-0608
This bottom-mounted x-groove Flux Core drive roll is serrated (hence the x-shape) to grab and feed softer flux cored wires (the drive roll is designated by either an X or K on the side following the size). It fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one X-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
  1. This is a .023"-.030" drive roll which may have markings of 0.6mm-0.8mm equivalent groove sizes.
  2. The groove is serrated for Flux-Cored wires. Do not use to feed Aluminum.
  4. .023" and .025" size wires use the same groove.
