Drive Roll Flux Core Single (Flux Core Wire)
$20.00
SKU# EV-DR-FC-1012
This bottom-mounted x-groove Flux Core drive roll is serrated (hence the x-shape) to grab and feed softer flux cored wires (the drive roll is designated by either an X or K on the side following the size). It fits multiple Everlast MIG welders equipped with a two-roll wire feed system. In this configuration, the lower drive roll feeds the wire, while the upper roll is typically a flat-surfaced idler that applies pressure to hold the wire in the lower roll’s groove. Only one X-grooved drive roll is required. Select the appropriate drive roll for the type and diameter of wire you are using.
Keep in Mind:
- This is a .040"-.045" drive roll which may have markings of 1.0mm-1.2mm equivalent groove sizes.
- The groove is serrated for Flux-Cored wires. Do not use to feed Aluminum.
- .045" and .047" size wires use the same groove.
