Hatchet 60, view 1
Hatchet 60, view 2
Hatchet 60, view 3
Hatchet 60, view 4
Hatchet 60, view 1
Hatchet 60, view 2
Hatchet 60, view 3
Hatchet 60, view 4
SKU# HTC-60
Hatchet 60
Hand Cutting Only
$949.00
$659.00
Save - $290.00
Hatchet 60
Hand Cutting Only
SKU# HTC-60
  • Unit Weight: 14 lb
  • Shipping Weight: 20 lb
  • Unit Dimensions: 8.5 in × 17.5 in × 13 in
Hatchet 60
The Hatchet 60 simply works. Its no-frills design delivers dependable cutting performance at a budget-friendly price. It’s well suited to small shops, factory maintenance, home garages, and auto body shops that need a reliable, straightforward plasma cutter. On 240V power, it is optimized for everyday cutting up to 9/16 inch and can sever material up to 1 inch thick.
  1. 120/240V Dual Voltage input
  2. Comfortable and maneuverable IPT-60 hand cutting torch
  3. Compact size with low weight
  4. Highly portable
  5. Cut guide printed on front panel
  6. IPT-60 hand cutting torch
Generator Requirements*:
  2. 10,000 Surge Watts
*Not following these requirements will void the plasma cutters's warranty.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 36 A
240V 1 Phase 50/60Hz: 41 A
120V 1 Phase 50/60Hz: 22 A
240V 1 Phase 50/60Hz: 25 A
Analog/No Display
Plasma Duty Cycle 120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 30A/92V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 25A/90V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 20A/88V Rated Output
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 60A/104V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 50A/100V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 40A/96V Rated Output
300V
Arc Start Type
Blowback, Piston Type
Torch Type
iPT60 Hand Torch
CNC Capable/Ready
Gouging Capable
Gouging Duties
No Gouging Permitted, Voids warranty
Drag Cutting
Yes, but only with included standoff
Post Flow Timer
Automatic
Parts-In-Place Safety Cut Out
Recommended Flow Rate (Air)
5.3 CFM
Maximum Supply Pressure
90
Compressor Built In
20 gallon
65-75 PSI
Remote
Tip Saver Function
Location of CNC Port
No CNC Port
Torch Connector Type
Euro- Central
  1. Up to 9/16" daily use
  2. Up to 7/8" clean cut
  3. Up to 1" severance cut
  4. Pierce up to 9/16"
Units are supplied with a starter set of consumables intended primarily for cutting in the 55-60 amp range.
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
  • Artistry
