Lightning 275 MTS (208V 1 Ph)
SKU# LMTS-275-208
- Unit Weight: 95 lb
- Unit Dimensions: 11.5 in × 26 in × 25 in
Built for professional welders, the Lightning MTS 275 (208V only) brings the power and versatility to handle demanding fabrication, maintenance, and repair work in one compact machine. From the shop to the field, its 275A MIG output, TIG capability, and 220A Stick output—including E6010—give you more ways to get the job done. It handles short-circuit and spray arc MIG welding, with dedicated settings for aluminum, stainless steel, and gas-shielded or gasless flux-core welding. Push-pull gun capability expands its versatility even further.
Setup is quick and straightforward. The improved PowerSET function provides starting settings based on basic application information in MIG, TIG, and Stick modes. All settings for the selected process appear on a single screen, keeping adjustments within easy reach. An updated HV TIG start system delivers more efficient starts.
Built for demanding work, the Lightning MTS 275 delivers a 60% duty cycle at maximum rated output in all three processes, with 100% duty cycle at 200A in MIG and TIG or 175A in Stick.
NOTICE: This special model has 208V Input. If your input power is 220V or greater, choose the standard 120/240V model. Do not use with 220-240V power or damage may result.
- 208V Model for lower volt power supply. Do not use with 240V
- MIG,TIG and Stick operation handles almost any common welding chore
- Cart and Cooler for TIG available as an option and works with rear outlet
- Spool Gun Capable (spool gun optional)
- Run-in features improves arc starting in MIG mode
- Push Pull Gun Capable (Push-Pull gun optional)
- 5.1" LCD HD 720 Screen for easy view of parameters
- 4 Roller drive system for smooth feeding of wire on longer guns and push-pull guns
- 12" or 8" roll capacity (10-12 lb. or 30-44lb.) provide economical choices of wire selection.
- Surge Watts 13,500
| Voltage/Phase | 208V 50/60 Hz
| Max Inrush Amps (I1Max) | 208V 50/60 Hz: 62 A
| Rated Effective Amps (I1Eff) | 208V 50/60 Hz: 37 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | 720
| Memory | 30 Programs
| MIG Duty Cycle 208V 50/60 Hz | 208V 50/60 Hz: 35% Duty Cycle @ 40°C at 275A/27.8V Rated Output
208V 50/60 Hz: 60% Duty Cycle @ 40°C at 250A/26.5V Rated Output
208V 50/60 Hz: 100% Duty Cycle @ 40°C at 200A/24V Rated Output
| MIG Output Range 208V 50/60 Hz | 208V 50/60 Hz MIG Amp DC Output Range: 30 to 275 Amps
208V 50/60 Hz MIG Volt DC Output Range: 15.5 to 27.8 Volts
| Open Circuit Voltage (OCV) | 74V
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 8”
12”
V-Groove
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
Spot
Stitch
| Wire Feed Speed | 600 IPM
| Torch/Gun | North 36 Series 10 Ft.
| Important MIG Specification Notes | his unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner if using the 24 series or 36 series gun.
| TIG Duty Cycle 208V 50/60 Hz | 208V 50/60 Hz: 35% Duty Cycle @ 40°C at 275A/21V Rated Output
208V 50/60 Hz: 60% Duty Cycle @ 40°C at 250A/21V Rated Output
208V 50/60 Hz: 100% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 208V 50/60 Hz | 208V 50/60 Hz TIG Amp AC Output Range: 15 to 275 Amps
208V 50/60 Hz TIG Volt AC Output Range: 10.6 to 21 Volts
208V 50/60 Hz TIG Amp DC Output Range: 10 to 275 Amps
208V 50/60 Hz TIG Volt DC Output Range: 10.4 to 21 Volts
Live Lift Start
| Start Amp Range AC | 15-(150)275A
| Start Amp Range DC | 10-(150)275A
| End Amp Range AC | 15-(150)275A
| End Amp Range DC | 10-(125)275A
| Pre-Flow Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| Pulse Amperage | 3-95% of Welding Amperage
| AC Frequency | 20-250 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 208V 50/60 Hz | 208V 50/60 Hz: 60% Duty Cycle @ 40°C at 200A/28V Rated Output
208V 50/60 Hz: 100% Duty Cycle @ 40°C at 160A/26.4V Rated Output
| Stick Output Range 208V 50/60 Hz | 208V 50/60 Hz Stick Amp DC Output Range: 10 to 200 Amps
208V 50/60 Hz Stick Volt DC Output Range: 20.4 to 28 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | Yes
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
1/16"- 7/32"
- Rail Car Industry
- Pipe and Structural
- 36 Series MIG Gun 3m 10 ft.
- Starter Consumable TIG Kit
- 6.5 Ft. Power Cable with NEMA 6-50 Power Plug (works with 208V)
