Lightning 275 MTS  Cart 301 and Cooler WC401 Bundle (120/240V), view 1
Lightning 275 MTS  Cart 301 and Cooler WC401 Bundle (120/240V), view 2
Lightning 275 MTS  Cart 301 and Cooler WC401 Bundle (120/240V), view 3
Lightning 275 MTS  Cart 301 and Cooler WC401 Bundle (120/240V), view 4
SKU# LMTS-275-120240-301-W401
MIG
$4,027.00
$3,108.00
Save - $919.00
MIG
  • Unit Weight: 95 lb
  • Unit Dimensions: 11.5 in × 26 in × 25 in
This bundle package has been created with the professional in mind. It offers the Lightning 275, the PowerCool 401 and the heavy duty PowerCart 301 as part of the bundle package. This package includes pretty much everything you might need to weld pretty much anything in the shop. It includes all the standard accessories included with the Lightning 275 120/240V model.
Includes:
  1. Lightning 275 MTS (Dual Voltage 120/240V model)
  2. Lightning 275 MTS accessory package
  3. PowerCool 401 Water Cooler
  4. PowerCart 301 Single Cylinder Welding Cart
  2. Surge Watts 13,500
  1. This welder ships with a water-cooled 18 Series TIG Torch. If you want to use without a water cooler, you will need to purchase a 26 series air-cooled TIG torch.
  2. This welder ships with a 36 series MIG gun configured for heavy commercial spray arc welding. It comes with a yellow liner for .045–.062" wire installed. For the best weld quality and wire feeding performance, use the smallest liner compatible with your wire diameter. A red liner (.040–.045") is available for .045" wire, and a blue liner is available for .035" and smaller wire. Purchase additional liners to match the wire sizes you plan to use.
  3. For welding below 230 amps or for short-circuit applications, purchase the optional 24 series MIG gun, which comes with a red .040–.045" liner. Liners are interchangeable between the two guns, provided they are the same length.
  4. Do not use .030" or smaller wire in a MIG gun longer than 15 feet.
  5. Gasless Flux-cored operation is limited with the standard gun and is only able to be used for short periods of time with the standard gun that comes with the unit. Performance may be marginal as well and damage to the gun may result. There are no conversion kits for this gun. A dedicated Flux-Cored gun should be used if it is to be used regularly with gasless flux-cored wire.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 43 A
240V 1 Phase 50/60Hz: 53 A
120V 1 Phase 50/60Hz: 34 A
240V 1 Phase 50/60Hz: 41 A
5.1 inches
Type
TFT
Resolution
720
30 Programs
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 150A/21.5V Rated Output
120V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 120A/20V Rated Output
120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 150 Amps
80V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-10 Seconds
0-30 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
8”
12”
.035”
V-Groove
4
V-Groove
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Spot
Stitch
Wire Feed Speed
120V: 425IPM 240V: 600 IPM
Torch/Gun
North 36 Series 10 Ft.
his unit is equipped with a heavy duty 36 series MIG gun designed for Spray arc welding and using larger .045" and .062" wires. If welding below 230A, purchase a 24 Series gun. If using .035" or smaller wire, also purchase a blue .023"-.035" liner for the 24 series or 36 series gun.
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 7/16""
.015" to 5/16"
.015" to 5/16"
.025"- 5/16"
1/16"- 7/32"
  • Rail Car Industry
  • Pipe and Structural
